Problem in sending SMS using SIM300 and PIC18F452
amit78
PostPosted: Mon Jun 04, 2012 8:14 am     Reply with quote
Hi all
I am trying to connect a GSM Modem (SIM300) to send SMS using PIC18F452.
1. While I am connecting SIM 300 module with PC HyperTrm its working file with the At commands. Using AT+CMGS, I can send SMS too.
2. Now while I wrote the following code using the PIC18F452, nothing is happening.
#include <18F452.h>
#FUSES HS, NOWDT, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, NOWRT
#use delay(clock=20000000)
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, stream=GSM, ERRORS)
#include <stdio.h>
    char s = 26; //0x1A;
    char b = 34;
    fprintf(GSM, "AT\r");
    delay_ms(900);
    fprintf(GSM, "ATE0\r");
    delay_ms(900);
    fprintf(GSM, "AT+CMGF=1\r");
    delay_ms(900);
    fprintf(GSM, "AT+CMGS=%c9674170493%c\r", b, b);
    delay_ms(3000);
    fprintf(GSM, "hello FROM mcu%c", s);
I have connected both with a RS232 cross cable. Note: only three pins are used: Pin 5(GND), Pin2(Rx) and Pin3(Tx).
3. Interesting thing is, while connecting this PIC board with my PC HyperTerm with 9600 baud, I am getting the strings in the Hypertrm. So I hope the Serial connection is OK.
4. I am using the following connection:
PIC->Max232-> || Max232->SIM300
Any Suggestion?
Gabriel
PostPosted: Mon Jun 04, 2012 8:34 am     Reply with quote
Make sure to disable Flow control on the Module when using 3 wires.
What is this
Char b = 34;
Try this better
Char b = 0x22;
its clearer Hex 0x22 = "
(i know its the same... IMO i thing its better to keep things in hex)
try swapping your tx/rx lines between your MAX 232 chips...
Sound dumb but who is who ( DTE / DCE ) sometimes gets confusing.
Swapping the lines usually gets rid of my problems.
Before trying to go directly to sending an SMS... code a small programm that detects if when you send AT you get OK back...
then move on.
G.
CCS PCM 5.078 & CCS PCH 5.093
amit78
PostPosted: Mon Jun 04, 2012 11:25 pm     Reply with quote
Very Happy Very Happy Very Happy
Yes Gabriel, you were right. Just swapping the rx/tx solves the problem. But I am not convinced. Because now it is a straight cable, not cross cable.
[PIC=>MAX232] Rx----> Rx [MAX232=>SIM300]
[PIC=>MAX232] Tx----> Tx [MAX232=>SIM300]
Any way I am getting the SMS.
Surely I will maintain the norms to write things in hex. So, from now I will use:
Char b = 0x22;
Thanks dude.
ckielstra
PostPosted: Tue Jun 05, 2012 2:02 am     Reply with quote
In the RS232 standard two types of devices are devined: DTE and DCE. DTE is short for Data Terminal Equipment; a device that converts user information into signals or reconverts received signals. Examples are computer, printer or terminal.
DCE stands for Data Communications Equipment and is the device sitting in between the DTE and the physical communication wire, i.e. your modem.
The DCE and the DTE are always connected with a straight cable. If you want to connect to DTE devices together this requires crossing the receive and transmit wires, a so called null modem or crossover cable.
Now your confusion comes from the standard definitions that say the signals are named from a DTE point of view. The Tx output on the DTE (computer) is connected to the Tx input on the DCE (modem). The name of the signal is the same on both sides, but what is an output on one side is connected to the same named input on the other side.
More info: http://www.bb-elec.com/bb-elec/literature/tech/faq_rs232_connections_work.pdf
ckielstra
PostPosted: Tue Jun 05, 2012 2:17 am     Reply with quote
Char b = 0x22;
Using hex, decimal, binary or ASCII is a matter of personal preference. I myself like to write ASCII when I want to define a specific character.
char b= 'a';
But to avoid confusion I probably wouldn't write
a = '"';
and use instead:
a = 0x22;
And when specifying the I/O bits in a TRIS register I use binary:
TRIS_A = 0b00110011;
Just use the notation that best fits the job. But what I don't like is your construct:
If you have to add comments to explain the hex-value then you are doing something wrong and should have coded the hex value immediately:
char s = 0x1A;
amit78
PostPosted: Tue Jun 05, 2012 6:26 am     Reply with quote
Thanks Ckielstra for your valuable comment. I will surely keep these in my mind.
Amit
ezflyr
PostPosted: Tue Jun 05, 2012 7:00 am     Reply with quote
Hi All,
Everyone seems to be missing an important point with this discussion. When you send the CMGS command, you need to enclose the phone number inside of quotation marks. You can do that right inside your fprintf statement directly by preceding the quotation marks with an escape character '\'. Do it like this, and get rid the the silly way you are doing it now.
fprintf(GSM, "AT+CMGS=\"5085551212\"\r");
John
Gabriel
PostPosted: Tue Jun 05, 2012 8:01 am     Reply with quote
@ezflyr: Right on! . . . indeed that was the key issue
