18f452: PWM Channels & Timers
waheed
PostPosted: Sat May 19, 2012 2:17 am     Reply with quote
I am new to Embedded Systems and need help regarding PWM & Timers.
18f452 has two CCP channels that can be used as 10 bit PWM Channels.
Can a single timer be used to operate both Channels.
I want to generate two PWM outputs which takes inputs from two POTs using ADC Channels.
Mike Walne
PostPosted: Sat May 19, 2012 3:07 am     Reply with quote
In CCS you have to read ALL three of:-
(1) PIC data sheet.
(2) CCS manual.
(3) CCS .h file for chosen PIC.
From '452 data sheet, Timer2 controls the period for both PWM channels.
I.e. they run at the same frequency.
Mike
