CCS USB Development Kit SPI Communication
SCSU_Student
PostPosted: Wed May 23, 2012 11:15 am     Reply with quote
Is there a way to use SPI communication with the CCS USB Development Kit 53314-451? The SDO pin does not have a port, it is only connected directly to the RS232 chip.
ezflyr
PostPosted: Wed May 23, 2012 11:48 am     Reply with quote
Most of us probably don't have that kit, so we don't know which PIC you are talking about, and we don't have access to the schematic for the board.
It sounds like you are saying that the hardware SPI SDO pin is connected directly to an RS232 level translator IC. If the IC is socketed, you could remove it to free up that line, or you could use a software SPI implementation on another pin.
John
PostPosted: Wed May 23, 2012 12:30 pm     Reply with quote
Tell us what you want to use SPI for.
SCSU_Student
PostPosted: Wed May 23, 2012 2:17 pm     Reply with quote
I am using SPI to control a DDS chip. I have been using the PIC 18F4455 on a breadboard but it takes up to much space.
The RS232 IC is not socketed. What I was thinking about doing is removing the RS232 IC because I do not need RS232 communication, then soldering a lead across from the SDO trace to where it goes into the RS232 connector on the board. I would then just plug in a cable to the RS232 connector. Here is a link to the board layout: http://www.ccsinfo.com/pdfs/product_PDFs/USB_board.pdf
Would that work or would there be a better way to do it.
The pin used as SDO for the 18F4550 is C7.
PostPosted: Thu May 24, 2012 1:34 pm     Reply with quote
Do you need to use hardware SPI ? Do you need the speed ?
If not, you can use software SPI. For that, you can either write
your own "bit bang" code, or you can use the #use spi() library
provided with the CCS compiler.
Post the manufacturer and part number of the DDS chip.
