HID Descriptor with 16Bit ints.
uN_Eof
Location: I live in Spain, with the toros, paella and tortilla
PostPosted: Tue May 15, 2012 3:41 pm     Reply with quote
Hello everyone,
I must use this HID descriptor, but I don't know how to send the 16bit ints.
This is the descriptor:
const char USB_CLASS_SPECIFIC_DESC[] = {
  0x05, 0x01,          /* Usage Page (Generic Desktop)                       */
  0x09, 0x04,          /* Usage (Joystick)                                   */
  0xa1, 0x01,          /* Collection (Application)                           */
  0xa1, 0x02,          /*   Collection (Logical)                             */
  0x15, 0x00,          /*     Logical Minimum (0)                            */
  0x26, 0xFF, 0xFF,    /*     Logical Maximum (65535)                        */
  0x75, 0x10,          /*     Report Size (16)                               */
  0x95, 0x04,          /*     Report Count (4)                               */
  0x09, 0x30,          /*     Usage (X)                                      */
  0x09, 0x31,          /*     Usage (Y)                                      */
  0x09, 0x32,          /*     Usage (Z)                                      */
  0x09, 0x35,          /*     Usage (Rz)                                     */
  0x81, 0x82,          /*     Input (Data, Variable, Absolute, Volatile)     */
  0x25, 0x07,          /*     Logical Maximum (7)                            */
  0x46, 0x3B, 0x01,    /*     Physical Maximum (315)                         */
  0x75, 0x04,          /*     Report Size (4)                                */
  0x95, 0x01,          /*     Report Count (1)                               */
  0x65, 0x14,          /*     Unit (Eng Rot: Degree)                         */
  0x09, 0x39,          /*     Usage (Hat Switch)                             */
  0x81, 0x42,          /*     Input (Data,Var,Abs,NWrp,Lin,Pref,Null,Bit)    */
  0x05, 0xFF,          /*     Usage Page (null)                              */
  0x81, 0x01,          /*     Input (Constant)                               */
  0x75, 0x08,          /*     Report Size (8)                                */
  0x25, 0x01,          /*     Logical Maximum (1)                            */
  0x75, 0x01,          /*     Report Size (1)                                */
  0x95, 0x0D,          /*     Report Count (13)                              */
  0x05, 0x09,          /*     Usage Page (Button)                            */
  0x19, 0x01,          /*     Usage Minimum (Button 1)                       */
  0x29, 0x0D,          /*     Usage Maximum (Button 13)                      */
  0x81, 0x02,          /*     Input (Data, Variable, Absolute)               */
  0x75, 0x03,          /*     Report Size (3)                                */
  0xc0,                /*   End Collection                                   */
  0xc0                 /* End Collection                                     */
I tried this:
unsigned int16 write[4] = {0,0,0,0};
void main() {
   usb_init();
   usb_task();
   usb_wait_for_enumeration();
   //write[0] = 0;
   while(1){
                output_high(PIN_D0);
      usb_task();
      while(!usb_put_packet(1, write, 4, USB_DTS_TOGGLE));
But it does not seem to work.
So if someone could help I would really like it.
Thanks.
