def Files for CCS compiler?
hello188
PostPosted: Tue May 15, 2012 2:22 pm     Reply with quote
Hi
I know that most of the functionalities in PIC's are accessible via use of CCS built in library functions.
However, sometimes it is necessary to manipulate a specific Special Function Register myself manually.
As a solution, I include a "Special Function Register definition header file" that contains definitions such as below
#DEFINE POSTINC0 0XFEE
#DEFINE POSTDEC0 0XFED
#DEFINE PREINC0 0XFEC
#DEFINE PLUSW0 0XFEB
#DEFINE FSR0H 0XFEA
#DEFINE FSR0L 0XFE9
#DEFINE WREG 0XFE8
#DEFINE INDF1 0XFE7
#DEFINE POSTINC1 0XFE6
#DEFINE POSTDEC1 0XFE5
So that I can write directly to register such as ADCON1.
However, creating such file is too tedious and time consuming so I am wondering if the compiler provides some method as to I can access special functions by name without definining it's mapping.
Thank you
PostPosted: Tue May 15, 2012 2:31 pm     Reply with quote
The CCS IDE (PCWH, PCWHD) has the ability to make it for you.
See the screenshots in this section:
Ability to Generate Customized Include Files with SFR Definitions
on this page:
http://www.ccsinfo.com/content.php?page=ideoverview
You need the IDE version of the compiler to do this.
PostPosted: Tue May 15, 2012 3:30 pm     Reply with quote
Apart from mentioning the option to generate a SFR definition file automatically, it should be said,
that the syntax understood by the CCS C compiler uses #byte and #word statements. Just review the compiler help.
