lcd code
andys
lcd code
PostPosted: Tue May 08, 2012 6:30 pm     Reply with quote
Is anyone who can explain how to use an lcd screen in conjunction with pic.
I try to check the ex_92lcd.c (example) but i confused.
PostPosted: Tue May 08, 2012 6:34 pm     Reply with quote
Post the manufacturer and part number of the LCD. Also post a link to
the website for your LCD.
andys
PostPosted: Wed May 09, 2012 9:59 am     Reply with quote
I don't have any lcd now. I try to learn how to use an lcd and then i buy one.
I need a basic describe how to use an lcd.
Mike Walne
PostPosted: Wed May 09, 2012 11:48 am     Reply with quote
You will learn most by USING an LCD.
Manufacuturers data sheets and CCS examples show HOW to use LCD.
I'd pay a little more for an LCD and get one which does NOT need negative voltage for contrast control.
Mike
PostPosted: Wed May 09, 2012 12:10 pm     Reply with quote
There are several types of LCDs, and each type has several variations.
That's why I asked what type you want to use. This page shows them:
http://www.lcd-china.com/Technical.asp?bclassname=technical%20info&sclassname=LCD%20Middle%20Rear%20Processes&sclassid=84
The most common type for PIC experiments is the Character LCD.
That's the middle one in the link above. It shows 4 rows of 16 characters.
The most common type is 2 rows of 16 characters.
So again, what type of LCD do you want to use ?
