make PIC 18F452 working in real time
maenabbasi
PostPosted: Sun May 06, 2012 5:40 am     Reply with quote
I am developing project using PIC18f452 I want pic operate an operation (step motor) for 20minutes not for non-ending loop , how i can do it ?
MKA
PostPosted: Sun May 06, 2012 8:28 am     Reply with quote
This is really just basic programming.
Instead of structuring your code as:
do what you want forever
Structure your code as:
do what you want until a time has passed
then sit and wait.
How you work out that the 'time has passed', would depend on how your stepper motor code is written. For instance, if it is a loop controlling a pulse train to a stepper, with a pulse being sent every 1mSec for example, then you could just loop for 20000 times. If however it doesn't have a fundamental 'time', then you can just use one of the timers to generate a clock, and wait till this shows the time has passed, or add an external chip, with a programmable 'alarm', and use this as the signal.
