16f887 timer problem
Tak
PostPosted: Sun Apr 22, 2012 10:36 pm     Reply with quote
#include "16f887.h"
#device adc=8
#device *=16
#include "ham.h" // contain ADC set up.
#include <stdio.h>
#FUSES HS, NOWDT
#use delay(clock=8000000)
volatile int8 a=0;
#int_TIMER1
void TIMER1_isr()
 set_timer1(20000);
 set_tris_d(0x00);
 set_tris_a(0x00);
 output_a(0xff);
 cau_hinh_adc(); //set up adc
 setup_timer_1(RTCC_INTERNAL|RTCC_DIV_16);
 enable_interrupts(int_TIMER1);
 set_timer1(20000);
 //enable_interrupts(GLOBAL);
  a=read_adc();
  printf(" %u",a);
  output_d(a);
I try to read ADC and send the value to PC's COM port. Everything worked fine. After that, i decide to make sample with Timer1 and it doesn't work any more. I tested again with this:
#int_TIMER1
void TIMER1_isr()
 set_timer1(20000);
 output_d(a);
 set_tris_d(0x00);
 set_tris_a(0x00);
 output_a(0xff);
 set_timer1(20000);
 enable_interrupts(GLOBAL); // enable this
  a=read_adc();
  printf(" %u",a);
COM port still get value from ADC but leds haven't run at all. Every code I put in TIMER1_isr() 's not run too Crying or Very sad. I use CCS 4.104
Thanks for any advices=.=
PostPosted: Mon Apr 23, 2012 12:51 pm     Reply with quote
Your constants are not correct. The "RTCC" constants are for Timer0.
You need to use the constants for Timer1. Look in the 16F887.h file
to find the correct constants.
Tak
PostPosted: Mon Apr 23, 2012 10:42 pm     Reply with quote
Thanks PCM. It did work. my silly Embarassed
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
