SIRC decoding
ERICOO
SIRC decoding
PostPosted: Sat Apr 21, 2012 4:14 am     Reply with quote
Somebody out there please help. I had been trying to decode Sony TV remote control all to no avail. I have read so much on this on the internet, but the theory seem far different from the practice. I used pic kit2 to analyze the data. It was ok, start 2.52 ms, short bit = 600,640 us. I found a code written in MikroC which I translated to CCS PCW with little modification. But the Timer1 readings are not as expected. What am I doing wrong ? Someone please help. Here is the code:
#include <16F887.h>
#use delay(clock=16000000)
#include <Flex_LCD.c>
#BYTE PIR1 = 0x0c
//#BIT INTF = 1
unsigned input_data, bit_count,i;
int16 CAPT = 0,CAPT1 = 0,CAPT2=0;
enum {
        Idle,
        Start_bit,
        Capture_bit
char Current_state = Idle;
char got_data = 0;
char Command_code, Device_code;
#int_ext // Interrupt name
void interrupt(){
     if(interrupt_active(int_ext)){
        switch (Current_state){
           case Idle:
                 set_timer1(0);
                 ext_int_edge(L_TO_H);            //interrupt on rising edge.
                      Current_state = Start_bit;
           //found the rising edge, check lenght for 2.4ms
           case Start_bit:
                    CAPT = get_timer1();
                    set_timer1(0);
                      //correct signal, move on to next state
                      if((CAPT>=2000)&&(CAPT>=2800)) {
                      //output_high(PIN_B1);// this pin will only go high when     //CAPT is b/w 44520 and 44590, dont know why
                         bit_count = 0;
                         input_data = 0;
                         Current_state = Capture_bit;
                         } else {
                            //fault signal, reset to Idle
           case Capture_bit:
                      //check plus length for 0 or 1, 0 = 1.2ms and 1 = 1.8ms
                      CAPT1 = get_timer1();
                    set_timer1(0);
                      if((CAPT>=900)&&(CAPT<=1500)){
                      //output_high(PIN_B2);// this pin will only go high when //CAPT is b/w 44520 and 44590, dont know why
                         input_data >>= 1;         // add 0 to received data
                         bit_count++;
                      }else {
                       if((CAPT>=1500)&&(CAPT<=2100)){
                       //output_high(PIN_B3);// this pin will only go high when //CAPT is b/w 44520 and 44590, dont know why
                            input_data >>= 1;
                            input_data |= 0x8000;     //add 1 to received data
                            bit_count++;
                      } else {
                            //error occurs, reset to Idle state
                            ext_int_edge(H_TO_L);    //interrupt on falling edge.
                      //compleat 12 bit
                      if(bit_count >= 12){
                         got_data = 1;
                         input_data >>= 4;
            default: Current_state = Idle;
      clear_interrupt(int_ext);       //clear interrupt flag.
        enable_interrupts(int_ext);
        enable_interrupts(global);
void main(){
//set_tris_b(0x01);
enable_interrupts(int_ext); // Enable named interrupt
ext_int_edge(H_TO_L); // Interrupt signal polarit
enable_interrupts(global); // Enable all interrupts
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
   set_timer1(0);
      lcd_init();
    printf(lcd_putc"\f");
    // lcd_gotoxy(11,1);
     lcd_putc ("IR DECODING");
    lcd_gotoxy(1,2);
    lcd_putc ("Command:");
//**********************************************************//// Introduced this section of the code to test timer1 and crystal
// if they are functioning properly using PIC KIT2 the result was OK
//***********************************************************    for(i=0;i<4;i++){
    set_timer1(63136);  // Timer1 interrupt flag will set in 2.4 ms.
    output_low(PIN_B4); // this pin was connected to PIC KIT2 for the test
                        //result of test gave 2.38 ms @ 40 ms window
    while(!(PIR1&(1<<0))){}// wait until interrupt flag is set
    output_high(PIN_B4);
    clear_interrupt(int_timer1);
    delay_ms(1);// test result gave 1.04 ms, @40ms window
//***********************************************************//I included this section to show the detected times which happens to differ from my expectations
  lcd_gotoxy(12,2);
   printf(lcd_putc,"%lu",CAPT);
   delay_ms(2000);
   lcd_gotoxy(12,2);
   printf(lcd_putc,"%lu",CAPT1);
   delay_ms(2000);
   lcd_gotoxy(12,2);
   printf(lcd_putc,"%lu",CAPT2);
   delay_ms(2000);
//***********************************************************          if(got_data){
           printf(lcd_putc"\f");// clear LCD
           lcd_putc ("IR DECODING");//print "IR DECODING"
           lcd_gotoxy(1,2);
           lcd_putc ("Command:");// print "Command:"
            Command_code = input_data & 0x7F;//extract command code from input_data
            Device_code = input_data >> 7;//get Device code from input data
            got_data = 0;
            if(Device_code == 1){
               switch (Command_code){
                  case 0:
                 lcd_gotoxy(12,2);
                 printf(lcd_putc,"%U",Command_code); break;
                  case 1:
                  lcd_gotoxy(12,2);
                  case 2:
                  lcd_gotoxy(12,2);
                  case 3:
                  lcd_gotoxy(12,2);
                  case 4:
                  lcd_gotoxy(12,2);
                  case 5:
                  lcd_gotoxy(12,2);
                  case 6:
                  lcd_gotoxy(12,2);
languer
PostPosted: Sat Apr 21, 2012 12:14 pm     Reply with quote
I haven't played with SIRC, and have no current plans for it. But DHouston from the following links usually has good information on the topic: http://www.sbprojects.com/knowledge/ir/index.php
PostPosted: Sat Apr 21, 2012 3:13 pm     Reply with quote
Learn to use the forum's search page. It's here:
http://www.ccsinfo.com/forum/search.php
Search for this:
Sony remote
And set the search to: Search for all terms
Examples of threads on Sony remote control:
http://www.ccsinfo.com/forum/viewtopic.php?t=26226
http://www.ccsinfo.com/forum/viewtopic.php?t=44113
http://www.ccsinfo.com/forum/viewtopic.php?t=38192
