GLCD with UC1698 Drivers
waleed.ahafeez
PostPosted: Wed Apr 11, 2012 6:21 am     Reply with quote
Dear All,
Hello, I am trying to use a graphic lcd (HGO160160) having UC169 controller. GLCD is of 160x160 pixels. I have tried all the drivers available at CCS forums but lcd is still blank. I am new to CCS so can't write drivers on my own. Anyone who have drivers for UC169 Graphic controller or anyone who can tell me that UC169 is compatible with which other graphic controller?
Mentioned is the link of UC169 Controller datasheet
http://www.trulydisplays.com/monochrome/specs/Ultra%20Chip%20UC1698%20Spec.pdf
Waleed
jeremiah
PostPosted: Wed Apr 11, 2012 6:44 am     Reply with quote
Just saying "I can't get it to work" and "I have tried all the drivers" doesn't really give us anything to really go on. We'll need the following info:
1. compiler revision + specific PIC you are using
2. A schematic of how the PIC and various parts are connected (you can use sites like Imageshack to post pics here)
3. A small, simple, compilable version of what you have tried to do. It needs FUSES, main, etc. However, since you haven't read the forum guidelines yet, I'll mention, do not post any CCS driver code that is provided with the compiler code. Just your code or code from the code library forum. It needs to be something we can put into CCS and compile as is. Just do something simple to the GLCD. Also, use the CODE tags provided to post it and make sure the formatting is readable.
waleed.ahafeez
PostPosted: Tue Apr 17, 2012 1:20 am     Reply with quote
Hi Jeremiah,
I am using PIC 18F452, with the following drivers for displaying data on the GLCD but don't how to use these drivers with Graphics header file, these drivers was provided by the GLCD manufacturers for 8051 Micro Controller, I changed the code to use with PIC 18F452 now it is displaying some data on the screen (but unfortunately most of data displaying on the screen is garbage) .
#include<18F452.h>
#include<stdio.h>
#include<stdlib.h>
#define uchar char
#define uint  int
#DEFINE wr  PIN_B0
#DEFINE rd  PIN_B1
#DEFINE cs  PIN_B2
#DEFINE cd  PIN_B3
#DEFINE rst PIN_B4
uchar  zimu[8][93]=
         0,   0,   0,   0,   0,   0,   0,   0, //' '
         0,   6,  95,  95,   6,   0,   0,   0, //'!'
         0,   7,   7,   0,   7,   7,   0,   0, //'"'
         20, 127, 127,  20, 127, 127,  20,   0, //'#'
         36,  46, 107, 107,  58,  18,   0,   0, //'$'
         70, 102,  48,  24,  12, 102,  98,   0, //'%'
         48, 122,  79,  93,  55, 122,  72,   0, //'&'
          4,   7,   3,   0,   0,   0,   0,   0, //'''
          0,  28,  62,  99,  65,   0,   0,   0, //'('
          0,  65,  99,  62,  28,   0,   0,   0, //')'
          8,  42,  62,  28,  28,  62,  42,   8, //'*'
          8,   8,  62,  62,   8,   8,   0,   0, //'+'
          0, 128, 224,  96,   0,   0,   0,   0, //','
          8,   8,   8,   8,   8,   8,   0,   0, //'-'
          0,   0,  96,  96,   0,   0,   0,   0, //'.'
         96,  48,  24,  12,   6,   3,   1,   0, //'/'
         62, 127, 113,  89,  77, 127,  62,   0, //'0'
         64,  66, 127, 127,  64,  64,   0,   0, //'1'
         98, 115,  89,  73, 111, 102,   0,   0, //'2'
         34,  99,  73,  73, 127,  54,   0,   0, //'3'
         24,  28,  22,  83, 127, 127,  80,   0, //'4'
         39, 103,  69,  69, 125,  57,   0,   0, //'5'
         60, 126,  75,  73, 121,  48,   0,   0, //'6'
          3,   3, 113, 121,  15,   7,   0,   0, //'7'
         54, 127,  73,  73, 127,  54,   0,   0, //'8'
          6,  79,  73, 105,  63,  30,   0,   0, //'9'
          0,   0, 102, 102,   0,   0,   0,   0, //':'
          0, 128, 230, 102,   0,   0,   0,   0, //';'
          8,  28,  54,  99,  65,   0,   0,   0, //'<'
         36,  36,  36,  36,  36,  36,   0,   0, //'='
          0,  65,  99,  54,  28,   8,   0,   0, //'>'
          2,   3,  81,  89,  15,   6,   0,   0, //'?'
         62, 127,  65,  93,  93,  31,  30,   0, //'@'
        124, 126,  19,  19, 126, 124,   0,   0, //'A'
         65, 127, 127,  73,  73, 127,  54,   0, //'B'
         28,  62,  99,  65,  65,  99,  34,   0, //'C'
         65, 127, 127,  65,  99,  62,  28,   0, //'D'
         65, 127, 127,  73,  93,  65,  99,   0, //'E'
         65, 127, 127,  73,  29,   1,   3,   0, //'F'
         28,  62,  99,  65,  81, 115, 114,   0, //'G'
        127, 127,   8,   8, 127, 127,   0,   0, //'H'
          0,  65, 127, 127,  65,   0,   0,   0, //'I'
         48, 112,  64,  65, 127,  63,   1,   0, //'J'
         65, 127, 127,   8,  28, 119,  99,   0, //'K'
         65, 127, 127,  65,  64,  96, 112,   0, //'L'
        127, 127,  14,  28,  14, 127, 127,   0, //'M'
        127, 127,   6,  12,  24, 127, 127,   0, //'N'
         28,  62,  99,  65,  99,  62,  28,   0, //'O'
         65, 127, 127,  73,   9,  15,   6,   0, //'P'
         30,  63,  33, 113, 127,  94,   0,   0, //'Q'
         65, 127, 127,   9,  25, 127, 102,   0, //'R'
         38, 111,  77,  89, 115,  50,   0,   0, //'S'
          3,  65, 127, 127,  65,   3,   0,   0, //'T'
        127, 127,  64,  64, 127, 127,   0,   0, //'U'
         31,  63,  96,  96,  63,  31,   0,   0, //'V'
        127, 127,  48,  24,  48, 127, 127,   0, //'W'
         67, 103,  60,  24,  60, 103,  67,   0, //'X'
          7,  79, 120, 120,  79,   7,   0,   0, //'Y'
         71,  99, 113,  89,  77, 103, 115,   0, //'Z'
          0, 127, 127,  65,  65,   0,   0,   0, //'['
          1,   3,   6,  12,  24,  48,  96,   0, //'\'
          0,  65,  65, 127, 127,   0,   0,   0, //']'
          8,  12,   6,   3,   6,  12,   8,   0, //'^'
        128, 128, 128, 128, 128, 128, 128, 128, //'_'
          0,   0,   3,   7,   4,   0,   0,   0, //'`'
         32, 116,  84,  84,  60, 120,  64,   0, //'a'
         65, 127,  63,  72,  72, 120,  48,   0, //'b'
         56, 124,  68,  68, 108,  40,   0,   0, //'c'
         48, 120,  72,  73,  63, 127,  64,   0, //'d'
         56, 124,  84,  84,  92,  24,   0,   0, //'e'
         72, 126, 127,  73,   3,   2,   0,   0, //'f'
        152, 188, 164, 164, 248, 124,   4,   0, //'g'
         65, 127, 127,   8,   4, 124, 120,   0, //'h'
          0,  68, 125, 125,  64,   0,   0,   0, //'i'
         96, 224, 128, 128, 253, 125,   0,   0, //'j'
         65, 127, 127,  16,  56, 108,  68,   0, //'k'
          0,  65, 127, 127,  64,   0,   0,   0, //'l'
        124, 124,  24,  56,  28, 124, 120,   0, //'m'
        124, 124,   4,   4, 124, 120,   0,   0, //'n'
         56, 124,  68,  68, 124,  56,   0,   0, //'o'
        132, 252, 248, 164,  36,  60,  24,   0, //'p'
        24,  60,  36, 164, 248, 252, 132,   0, //'q'
        68, 124, 120,  76,   4,  28,  24,   0, //'r'
        72,  92,  84,  84, 116,  36,   0,   0, //'s'
        0,   4,  62, 127,  68,  36,   0,   0, //'t'
        60, 124,  64,  64,  60, 124,  64,   0, //'u'
        28,  60,  96,  96,  60,  28,   0,   0, //'v'
        60, 124, 112,  56, 112, 124,  60,   0, //'w'
        68, 108,  56,  16,  56, 108,  68,   0, //'x'
        156, 188, 160, 160, 252, 124,   0,   0, //'y'
        76, 100, 116,  92,  76, 100,   0,   0, //'z'
        8,   8,  62, 119,  65,  65,   0,   0, //'{'
        0,   0,   0, 119, 119,   0,   0,   0, //'|'
void write(int1 flag,int dat)
   output_low(cs);
   if (flag==0)
   output_low(cd);
   if (flag==1)
   output_high(cd);
   output_low(wr);
   output_high(rd);
   output_d(dat);
   output_high(wr);
void init(void)//*
   output_low(cs);
   /*reset*/
   output_low(rst);
   delay_ms(2);         //power on reset
   output_high(rst);
   delay_ms(200);
   write(0,0xe2);         //reset by command
   delay_ms(2);
   /*power control*/
   write(0,0xe9);         //(26)Bias Ratio:1/10 bias
   write(0,0x2b);         //(6)power control set as internal power
   write(0,0x25);         //(5)set temperate compensation as 0%
   write(0,0x81);         //(10)electronic potentionmeter
   write(0,0xbf);
   /*display control*/
   write(0,0xa4);         //(15)all pixel off
   write(0,0xa6);         //(16)inverse display off
   /*lcd control*/
   write(0,0xc0);         //(18)partial display and MX disable,MY enable
   write(0,0xa3);         //(14)line rate 15.2klps
   write(0,0xd1);         //(20)rgb-rgb
   write(0,0xd5);         //(21)4k color mode
   write(0,0x84);         //(11)partial display control disable
   /*(19)n-line inversion*/
   write(0,0xc8);
   write(0,0x10);         //enable NIV
   /*(22)com scan fuction*/
   write(0,0xda);         //enable FRC,PWM,LRM sequence
   /*window*/
   write(0,0xf4);         //(30)wpc0:column
   write(0,0x25);         //start from 130
   write(0,0xf6);         //(32)wpc1
   write(0,0x5a);         //end:272
   write(0,0xf5);         //(31)wpp0:row
   write(0,0x00);         //start from 0
   write(0,0xf7);         //(32)wpP0
   write(0,0x9F);         //end 160
   write(0,0xf8);         //(34)inside mode AC3
   write(0,0x89);         //(12)RAM control,ÏÔʾ·½Ïò
   write(0,0xad);         //(17)display on,select on/off mode.Green Enhance mode disable
   /*scroll line Óë RAM µÄÓ³Éä¹Øϵ*/
   write(0,0x40);         //(8)low bit of scroll line
   write(0,0x50);         //high bit of scroll line
   write(0,0xc4);         //(18)partial display and MX disable,MY enable
    write(0,0x90);         //(13):FLT,FLB set
   write(0,0x00);
   /*partial display*/
   write(0,0x84);         //(11),set partial display control:off
   write(0,0xf1);         //(27)com end
   write(0,0x9f);         //160
   write(0,0xf2);         //(28)display start
   write(0,0);            //0
   write(0,0xf3);         //(29)display end
   write(0,159);         //160
void words(uchar x,uchar y,uchar *p)         //type=1,ascii;type=2,Chinese character
   uchar i,k,j,m,n,l,x0,dat0,dat1,dat2,dat3,dat4,dat5,dat6;
   x=37+x;
   x0=0x00|(x&0x0f);
   x=0x10|((x&0xf0)>>4);
      for(j=0;j<8;j++)
         m=i*8+j;
         write(0,0x89);//SET RAM ADDRESS CONTROL
         write(0,x0);//Set Column Address LSB CA[3:0]
         write(0,x);//Set Column Address MSB CA[7:4]
         write(0,0x60|((y+m)&0x0f));//Set Row Address LSB RA [3:0]
         write(0,0x70|(((y+m)&0xf0)>>4));//Set Row Address MSB RA [7:4]
         for(k=0;k<2;k++)
            l=k*6+n;
            dat6=0x01<<j;
            dat0=(*(p+l))&dat6;
            dat0=dat0>>j;
            dat0<<=7;
            dat1=(*(p+l+1))&dat6;
            dat1=dat1>>j;
            dat1<<=3;
            dat2=*(p+2+l)&dat6;
            dat2=dat2>>j;
            dat2<<=7;
            dat3=(*(p+3+l))&dat6;
            dat3=dat3>>j;
            dat3<<=3;
            dat4=(*(p+4+l))&dat6;
            dat4=dat4>>j;
            dat4<<=7;
            dat5=(*(p+5+l))&dat6;
            dat5=dat5>>j;
            dat5<<=3;
            write(1,dat0|dat1);
            write(1,dat2|dat3);
            write(1,dat4|dat5);
      write(0,0x88);//SET RAM ADDRESS CONTROL
void lcdscan(uchar dat1,uchar dat2)
   uchar i,j;
   write(0,0x60);         //row address LSB
   write(0,0x70);         //row address MSB
   write(0,0x05);         //culomn address LSB
   write(0,0x12);         //culomn address MSB
   for(j=0;j<160;j++)
      for(i=0;i<27;i++)
         if(j%2==0)
            write(1,dat1);
            write(1,dat1);
            write(1,dat1);
            write(1,dat2);
            write(1,dat2);
            write(1,dat2);
void character(void)
   uchar *q;
   uchar i,j;
   lcdscan(0x00,0x00);
   for(i=0;i<8;i++)//controller:
      q=zimu[i];
      j=4*i+4;
      words(j,0,q);
   for(i=11;i<18;i++)//uc1698u
      q=zimu+i*36;
      j=4*(i-11)+4;
      words(j,70,q);
init();
character();
