External Clock PIC16F688
Goto page 1, 2, 3  Next
quicksilver
PostPosted: Wed Mar 21, 2012 8:00 am     Reply with quote
Hey guys, I got very surprised the other day when I removed the crystal from my board and the PIC kept working. Surprisingly, I couldn't use the sleep routine. So, my doubt is... What fuse do I need to activate in order to my PIC works with an external clock???
I found this fuse: #fuse EC_IO. But I couldn't get my PIC working with an external clock. I put 4MHz crystal with two capacitors in the respective pins, but even with this, my PIC didn't start.
Thanks beforehand guys.
everything that has a beginning, has an end
asmboy
PostPosted: Wed Mar 21, 2012 8:19 am     Reply with quote
post your code and compiler versioin
quicksilver
PostPosted: Wed Mar 21, 2012 8:32 am     Reply with quote
I'm using Version 4.038. And the part of the code is this one.
#fuses XT, NOWDT, NOBROWNOUT, NOPUT, NOMCLR, EC_IO
And I think the fuses is the problem about this, because I don't have any more things in my code. If I remove the EC_IO the PIC will start working with or without an external clock. So, how can I tell to my compiler to use an external clock???.
asmboy
PostPosted: Wed Mar 21, 2012 9:43 am     Reply with quote
HAVE YOU TRIED HS instead of XT ??
#fuse PUT,HS ...... ??
YOU NEED TO allow PUT to operate with an ext crystal
you can see if you are getting oscillation on the osc OUT pin
of the pic on an oscilloscope too
you might s have a problem with the size ( or connection) of your crystal phasing capacitors too
quicksilver
PostPosted: Wed Mar 21, 2012 9:58 am     Reply with quote
But if I'm using a 4MHz Crystal... Can I use the HS fuse???
PostPosted: Wed Mar 21, 2012 10:34 am     Reply with quote
Whoa.
You can only have _one_ oscillator fuse. If you are using an external oscillator module, EC_IO, and _get rid of HS, or XT_.
If you are using an external crystal (not a complete oscillator), then get rid of EC_IO, and just have HS or XT.
Having both gives an invalid oscillator configuration for either setup.....
The oscillator settings are mutually exclusive.
At 4Mhz, XT should work. HS 'may work' if the crystal gain is low, but can cause problems on some chips, with the input being overdriven.
However if you have a particularly low gain crystal, then HS may be needed.
quicksilver
PostPosted: Wed Mar 21, 2012 10:50 am     Reply with quote
Which value's capacitor you suggest??? I have 10pF.
asmboy
PostPosted: Wed Mar 21, 2012 11:04 am     Reply with quote
I have 10pF.
depedns on XTAL SPEC
for 4 mhz AT cut i'd try 22pf or 33pf with XT fuse
quicksilver
PostPosted: Wed Mar 21, 2012 12:14 pm     Reply with quote
OK guys... I'm trying to do this... because I think that my biggest problem is that I'm using the sleep routine, but, doesn't work, that's anybody has an example that works???
PostPosted: Wed Mar 21, 2012 12:37 pm     Reply with quote
Walk first.
Prove your chip is working, and at the right frequency.
Just do a 'toggle pin' routine, with a specified delay, and time that the delay is right.
Only move on to trying to sleep, once you are sure this is all working.
On sleep, depends what you want to wake it up?. Remember you can only wake using things that keep running, when the chip is asleep, The data sheet tells you what can do this. So, hardware interrupt - yes. Serial receive - no. Watchdog - yes, but relatively innacurate. Also remember it takes a long time to wake up the crystal.
quicksilver
PostPosted: Wed Mar 21, 2012 12:57 pm     Reply with quote
Guys, even I can't turn on a LED with this... what is the problem??? I can't find it... can someone point it out??? Please???
#include <16F688.H>
#fuses NOWDT, NOBROWNOUT, PUT, NOMCLR, EC_IO
short flag_timer=0;
#int_TIMER1
void  TIMER1_isr(void)
   set_timer1(0);
   flag_timer=1;
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_8);
while(true){
   sleep();
   if(flag_timer)
   flag_timer=0;
   output_high(pin_c5);
   output_low(pin_c5);
[/code]
drh
PostPosted: Wed Mar 21, 2012 1:08 pm     Reply with quote
Change T1_EXTERNAL to T1_INTERNAL
Are you using an external oscillator or a xtal with capacitors? Your FUSE is set up for an external oscillator. For a xtal, use either XT or HS.
David
quicksilver
PostPosted: Wed Mar 21, 2012 1:13 pm     Reply with quote
I tried all of them. If I remove the sleep routine, it will work, so I'm confuse... I need and external crystal to make the interruption, right??? that's anybody has a clue about what is going on here with this code???
asmboy
PostPosted: Wed Mar 21, 2012 2:35 pm     Reply with quote
#include <16F688.H>
#Fuses XT,NOWDT,PUT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,
#fuses NOIESO,NOFCMEN,
   while(true){
    output_toggle(pin_c5);
does this work for you or not ???
quicksilver
PostPosted: Wed Mar 21, 2012 2:42 pm     Reply with quote
Well... I'm trying to save energy, I have to save it... that's why I need to work with the sleep mode, So I'm trying to use the external clock to generate an interruption with the external clock, but, it doesn't work.
Page 1 of 3
