jspencer
Joined: 22 Dec 2003 Posts: 57 Location: Boise, ID USA
| MCP9700 C library |
Posted: Fri Aug 11, 2006 12:56 pm |
I'm looking at using the MCP9700. Does anyone know if there is a C library already out there that has been written? It can be in either CCS C or Microchip C. I've got the one in assembly and just wanting to know if there is a better starting point out there. If not then I'll just port the assembly code.
Thanks,
jspencer |
kender
Posted: Fri Aug 11, 2006 5:29 pm |
From what I could understand from the MCP9700 datasheet, it’s an analog sensor. So if you know how to read the A/D on a PIC, you can get the reading with just a few lines of code.
// assuming that the A/D is set up already
int16 iReading;
set_adc_channel(YOUR_MCP9700_CHANNEL); // switch the A/D channel
delay_us(10); // give the mux some time to settle
iReading = read_adc(); // get the reading from the A/D
Well, this could be a starting point. Look up also the code for LM35 temperature sensor in the forum. It’s another analog temperature sensor similar to MCP9700. |
jspencer
Posted: Mon Aug 14, 2006 8:54 am |
Thanks for the info and taking the time to look at the datasheet. I should have been a little more specific in what I was looking for. I was looking for the calibration and temperature compensation routines. I think that I got most of it ported to C now from the assembly, just need to run some tests and make sure that everything is working as I would expect.
Thanks,
jspencer |
Darkforces
| Help with temperature using mcp9700 |
Posted: Tue Apr 17, 2012 2:13 pm |
| jspencer wrote: | Thanks for the info and taking the time to look at the datasheet. I should have been a little more specific in what I was looking for. I was looking for the calibration and temperature compensation routines. I think that I got most of it ported to C now from the assembly, just need to run some tests and make sure that everything is working as I would expect.
Thanks,
jspencer |
Can you help me with your docs about temperature measurements with mcp9700? If possible send me by email.
Thanks,
Darkforces |
