problem with dynamic memory in multi-files project
Posted: Fri Mar 30, 2012 6:27 am
Dear sir.
I used PIC18F4553 and PIC16F877 with CCS V4.
I did multi-file compilation unit for my project and it worked fine.
But when I used dynamic memory functions (calloc/malloc) in my programs, those functions did not work. They returned NULL pointers.
I read the Multiple Compilation Units topic in Help file and followed it.
I also included stdlibm.h in the common header file of the project.
I debugged it with MPLABSIM and I saw the variable DYNMIC_HEAD was zero, that caused malloc/calloc returned NULL pointer .
I also did single-file project with malloc/calloc and it worked correctly.
Best Rgds.
Posted: Fri Mar 30, 2012 11:47 am
Which CCS version 4? It will be a number 4.xxx . If my memory serves the earlier versions had problems in this area. _________________ Google and Forum Search are some of your best tools!!!!
