DS1820 & PIC18F452
ihsanbu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
DS1820 & PIC18F452
PostPosted: Fri Mar 30, 2012 11:41 pm     Reply with quote
Hi All
I connect ccs forum after long time.
I am working on temperature control system mini project. Hardware is ready but I face the following problem:
1- I want use this code for PIC18f452 micro.
The code is:
//     temperature control system demos        //////
//#include <18F452.h>
//#device adc=10
//#device *=16
//#device adc=10
//#fuses HS,NOWDT,NOPROTECT,NOLVP
//#use delay(clock=4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
//////////////////////////decleard function//////////////////////////////////////
//#include <lcd.c>
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#include<1wire.c>
#include<lcd.c>
//#include <kbd.c>
#include<ds1820.c>
float temperature;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
lcd_init();
lcd_putc("\f");
while (1)
  temperature = ds1820_read();
  lcd_gotoxy(1,1);
  printf(lcd_putc,"TEMP: %3.1f ", temperature);
  lcd_putc(223);
  lcd_putc("C   ");
  lcd_gotoxy(1,2);
  if(temperature >= 29.0)
   printf(lcd_putc,"Hot!  ");
   //output_high(PIN_C0);     // red led 'ON'
   //output_low(PIN_C1);     // yellow led off
   //output_low(PIN_C2);     // led off.
   //output_high(PIN_C3);     // disable WPL relay
  else if( temperature >= 20 && temperature < 29.0)
   printf(lcd_putc,"Comfort!");
   //output_low(PIN_C0);     // red led 'ON'
   //output_high(PIN_C2);     // yellow led off
   printf(lcd_putc,"Cold!   ");
  // output_low(PIN_C0);     // red led 'ON'
   //output_low(PIN_C2);     // yellow led off
   //output_high(PIN_C2);     // led off.
Using PIC16F877a its working well but I have PIC18F452 micro chip now.
So how I can do this ? Using above given pic18f452 it will give error message.
Thank you in advance.
ihsan ullah khan
Embedded Designer Since 2003
Mike Walne
PostPosted: Sat Mar 31, 2012 2:14 am     Reply with quote
Read the CCS forum guide.
It would have helped if you said what the compiler is objecting to, rather than making us work it out.
The setup for the comparators and ADC are different on the two chips.
Read the microchip manuals to figure out the setups you want.
Then look up the new syntax in the 18F452.h file.
Mike
