new user
nikolasvr
new user
PostPosted: Wed Mar 21, 2012 6:40 am     Reply with quote
I am a new user and i would like to ask you that :
I have this code and i want to stuck the prog when it print the "LOW" or "HIGH" condition, not to running all the time. How can i do that?
main()
if (input(pin_A0)==0)
   printf("\r\nLOW");
if (input(pin_A0)==1)
   printf("\r\nHIGH");
SherpaDoug
PostPosted: Wed Mar 21, 2012 7:11 am     Reply with quote
The while(1) is what makes it run continuously. However you need to keep the PIC running long enough to send the serial strings, so you can not stop the program right after the print statements.
You could remove the main while(1) loop and add a while(1) after each of the print statements. Then the PIC would boot, test the pin, print the appropriate message, and then stay in a loop forever. That sounds like what you want.
For better style you should look at using an if/else construction.
nikolasvr
PostPosted: Mon Mar 26, 2012 9:50 am     Reply with quote
I know about while(1), is it possible to have an example?
SherpaDoug
Re: new user
PostPosted: Mon Mar 26, 2012 10:17 am     Reply with quote
main()
   printf("\r\nLOW");
   printf("\r\nHIGH");
main()
   printf("\r\nLOW");
   printf("\r\nHIGH");
nikolasvr
PostPosted: Mon Mar 26, 2012 10:26 am     Reply with quote
I'm trying this code but when I change the state of input, it do nothing.....
rnielsen
PostPosted: Mon Mar 26, 2012 11:17 am     Reply with quote
main()
  while(1)// main loop
    if(input(pin_A0) == 0)// if the input is LOW
      printf("\r\nLOW");
      while(input(pin_A0) == 0)// stay here if the input is still LOW
    if(input(pin_A0) == 1)// if the input is HIGH
      printf("\r\nHIGH");
      while(input(pin_A0) == 1)// stay here if the input is still HIGH
  }// end of while loop
}// end of main()
nikolasvr
PostPosted: Mon Mar 26, 2012 11:01 pm     Reply with quote
Thank you very much my friend!!
