Simple HID USB Class Program not working pls help...
07arunsharma
PostPosted: Wed Mar 28, 2012 11:31 am     Reply with quote
Hello!! Everyone!!!
I am new to CCS PIC-C and wants to do some usb programming with it.
Earlier i had used mikroC but doesn;t like that much..
I had write a simple code, which displays the data on lcd which is sent from PC, suppose i send "arun sharma" it must be displayed on LCD.
But i a unable to do so properly.
Here is my Code
//rhydoLABZ PIC18F4550 Development Board
#include <18F4550.h>
#device ADC=8
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
//RS232 Configuration
#use rs232(baud=9600, UART1, errors)
#define LED1 PIN_B7
#define LED2 PIN_B6
#define LED3 PIN_B5
//Transmit and Receive Packet Size
#define USB_CONFIG_HID_TX_SIZE 16
#define USB_CONFIG_HID_RX_SIZE 16
/*******VENDOR ID AND PRODUCT ID********/
#define USB_CONFIG_PID 1      //Chnage Vendor Id and Product Id
#define USB_CONFIG_VID 4660      //So that they will work with my Application
/*******LCD Pin Configuration******/
#define LCD_ENABLE_PIN PIN_C2
#define LCD_RS_PIN PIN_C1
#define LCD_RW_PIN PIN_C0
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include<pic18_usb.h>
#include<usb_desc_hid.h>
#include<usb.c>
#include<lcd.c>
//Macro Definition for LED ON and OFF
#define LED_ON(x) output_low(x)
#define LED_OFF(x) output_high(x)
void usb_debug_task(void)
   static int8 last_connected;
      static int8 last_enumerated;
      int8 new_connected;
      int8 new_enumerated;
      new_connected = usb_attached();
      new_enumerated = usb_enumerated();
   if (new_enumerated)
         LED_ON(LED1);
         LED_OFF(LED1);
      if (new_connected && !last_connected)
         printf("\r\n\nUSB connected, waiting for enumaration...");
      if (!new_connected && last_connected)
         printf("\r\n\nUSB disconnected, waiting for connection...");
      if (new_enumerated && !last_enumerated)
       printf("\r\n\nUSB enumerated by PC/HOST");
      if (!new_enumerated && last_enumerated)
       printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
      last_connected=new_connected;
      last_enumerated=new_enumerated;
   unsigned char in_data[16];
   unsigned int i;
   set_tris_b(0x00);   //Port-B as Output Port
   set_tris_c(0x10);
   output_b(0x00);
   LED_OFF(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   lcd_init();      //Initialize the LCD Module
   lcd_gotoxy(3,1);
   lcd_putc("PIC18F4550");
   Delay_ms(1000);
   lcd_gotoxy(3,2);
   lcd_putc("USB EXAMPLE!");
   printf("\r\n\nUSB Test Program--->Written in CCS PIC-C");
   printf("\r\nEMBEDDED LABORATORY\r\n");
   usb_init_cs();
   Delay_ms(1000);
   lcd_putc("\fRECEIVED DATA:-");
   Delay_ms(1);
      usb_task();
      usb_debug_task();
      if(usb_enumerated())
         if(usb_kbhit(1))
            lcd_gotoxy(2,1);
            lcd_putc("                ");
            usb_get_packet(1,in_data,2);
            printf("\r\nReceived Data: ");
            for(i=0;i<16;i++)
               printf("%c",in_data[i]);
               //Send the Recevied Data to Serial Port
               lcd_gotoxy(1,2);
               lcd_putc(in_data[i]);
            //Now Clear the in_data array
            for(i=0;i<16;i++)
               in_data[i] = '\0';   //Null Character
I am using the application given with mikroC to communicate from PC and also the given on this site
http://sites.google.com/site/coolembeddedlaboratory/home/visual-basic
according to me the application are working fine,
this program works satisfactory when i had not change the
and retain them to the value of 2
But that doesn't fulfill my requirements.
at least a array of size 16 is must for me...
Can any one tell me why my program doesn't works.
NOTE:-
#define USB_CONFIG_HID_TX_SIZE 2
#define USB_CONFIG_HID_RX_SIZE 2
By using this
everything works fine..
Pls Help
Thanks in Advance
Arun Sharma
