Capsense issues with Pic16f1939
kbruin79
PostPosted: Tue Mar 27, 2012 4:05 pm     Reply with quote
Ever since I migrated from the Pic16f727 to the Pic16f1939 I started having problems with the capsense sensitivity. The capsense module won't detect a finger press with an overlay anymore. It seems it's much less sensitive and even if I push the scan time to the max the module won't detect any finger press.
Here is the code and like I said it worked fine with the Pic16f727
Compiler version 4.128. Any idea how to resolve the sensitivity issue is appreciated. Thank you
#include <16F1939.h>
#fuses   INTRC_IO, NOWDT, NOPROTECT, NOMCLR,VCAP_A6
#use     delay(clock = 8000000)
#include "flex_lcd.c"
// use the manual way for assigning IO pins
#use     fast_io (C)
                                       //CAP1      CAP2       CAP4       CAP10      CAP9
#use touchpad(scantime=67ms threshold=3,PIN_D1='5',PIN_D2='4',PIN_D0='3',PIN_D4='2',PIN_D3='1')
                                      //PIN_D1='1',PIN_D2='2',PIN_D5='3',PIN_D0='4',PIN_D4='5'
//gloable variable declaration
char c='0';
char previous_sensor_id=0;
char current_sensor_id;
char user_selection;
int8  scroller=0;
int8 display_delay=8;
//function prototypes:
int8 scroll_wheel_value(void);
void make_LCD_pins_digital(void);
   make_LCD_pins_digital();
   lcd_putc("\fTime \n");
   lcd_putc(" Calibrating ");
   delay_ms(200);
   //calibrates, then enters normal state
   TOUCHPAD_STATE(1);
  do
   scroll_wheel_value();
   switch (c)
      //start time lapse;
      case '5':
      printf(lcd_putc,"\f%c%s",126,"Start TM ");
      lcd_putc("\n Set Time Date");
      user_selection='5';
      delay_ms(display_delay);
      //IR OUT
      //GPIOD_5=1;
      //delay_ms(10);
      case '1' :
      lcd_putc("\f Start ");
      printf(lcd_putc,"\n%c%s",126,"Set Time Date");
      user_selection='1';
      case '2':
      lcd_putc("\f Set Time Date");
      printf(lcd_putc,"\n%c%s",126,"expo");
      user_selection='2';
      case '3':
      lcd_putc("\f exposure");
      printf(lcd_putc,"\n%c%s",126,"Trigger");
      //printf(lcd_putc,"\n%c%s",126,"Motion
      user_selection='3';
      case '4':
      lcd_putc("\f Trigger");
      //lcd_putc("\f lapse");
      printf(lcd_putc,"\n%c%s",126,"Setting");
      user_selection='4';
    }while(1);
    if(touchpad_hit())
       c=touchpad_getc();
      //lcd_putc("\ftouchpad pressed");
      current_sensor_id=c;
      if (current_sensor_id > previous_sensor_id)
         if ((current_sensor_id=='5')&&(previous_sensor_id=='1'))
          --scroller;
          ++scroller;
     else if ((current_sensor_id < previous_sensor_id))
          if ((current_sensor_id=='1')&&(previous_sensor_id=='5'))
           ++scroller;
          --scroller;
       previous_sensor_id=c;
     //c='0';
     return(scroller);
  return(scroller);
