RTOS and CAN 18f2580
Lemosek
PostPosted: Tue Mar 20, 2012 11:09 am     Reply with quote
Hello, I have strange problem. I write a simple code:
#include <18F2580.h>
#fuses HS, NOPROTECT, PUT, BROWNOUT, NOWDT, NOLVP
#use delay(clock=20M)
#use rtos(timer=1,minor_cycle=20ms)
#include <can-18F4580.c>  // Use correct driver
#include "button.c"
//definicje ID CAN
#define BOARD_ID_LEDMATRIX 30
#define BOARD_ID_MAIN_LEDMATRIX 31
//*************** Global variables ****************
int8 sem;
struct rx_stat rxstat;
int32 rx_id;
int32 tx_id;
int8 rx_len;
volatile int8 buffer_rcv[8];
int8 buffer_tx[8];
//*************************** TASK *****************************
#task(rate=200ms,max=20ms)
void Led_button_task ( );
#task(rate=1000ms,max=20ms)
void Button_task ( ); // odczyt stanu przycisków co 10ms
//======== button task =====//
void Button_task(){
    can_putd(BOARD_ID_MAIN_LEDMATRIX, buffer_tx, 1, 1, 1, 0);
void Led_button_task()
//CAN
can_init();
  sem=1;
  rtos_run();
Compiler warning:
Warning 216 Interrupts disabled during call to prevent re- entrancy: (can_set_id)
Why I have this warning??
CCS PCH C Compiler, Version 4.128.
In past I write some code with CAN bus and RTOS for dsPIC30f6010A and I also use Can_putd function in tasks and don't have this warning.
Best regards
R.L.
PostPosted: Tue Mar 20, 2012 3:07 pm     Reply with quote
Both can_putd() and can_init() call the can_set_id() function.
I don't have the CCS RTOS, but apparently tasks are called from within
an interrupt routine.
void Button_task(){
That would explain why you get the "interrupts disabled" warning.
I don't have the PCD compiler, but it's possible that it allows nested
interrupts and re-entrant routines. I have no experience with dsPICs
or PCD. But that could explain the difference. Or, it's also possible
that you had Warnings disabled when you used the PCD compiler.
