dac_mcp4822
rikotech8
dac_mcp4822
PostPosted: Thu Mar 15, 2012 1:55 pm     Reply with quote
Hello!
First, excuse my bad english!
Here is my problem. I'm trying to drive DAC (creation of the microchip). It is a 12bit D/A converter. The remain four bits (to 16) are configuration bits.
For example: 15bit - select dac(a|b), 14bit unusable(don't care) 13bit-coefficient (coef.*U_reference) , 12bit - dac_enable. So I tried to set these bits to logic '1', and then remaining 12 data bits. Unfortunately, without success. I developed my code to this level.
#include <18F2520.h>
#use delay(internal=8000000,RESTART_WDT)
#FUSES WDT,WDT128, NOPUT,NOBROWNOUT, NOMCLR, NOLVP, NOPROTECT
#use rs232(baud=9600,xmit=PIN_B0,rcv=PIN_B2)
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define sel_dac sent.word,15
#define gain sent.word,13
#define dac_enable sent.word,12
#define PIN_CS pin_C4  //chip select
#define PROG_EXE pin_A0 //indicate start of executing program
union combine{
int8 part[2];
int16 word;
}sent;
MCP_4822_set(){
    for(sent.word=0;sent.word<0xfff;sent.word++){
      bit_set(sel_dac);
      bit_set(gain);
      bit_set(dac_enable);
      spi_write(sent.part[1]);
      spi_write(sent.part[0]);
      delay_ms(10);
setup_spi(spi_master|spi_mode_0|SPI_CLK_DIV_64);
while (true)
   mcp_4822_set();
The chip send only configuration bits (15,13 and 12) and none data. I tried with the #bit function, but the result was the same :(
I hope you understand my problem, and maybe someone is going to help me. Thx in advance!
PostPosted: Thu Mar 15, 2012 2:23 pm     Reply with quote
Do a search of the forum archives, using the forum's search page.
I found two threads with sample drivers for the MCP4822. There may
be more.
http://www.ccsinfo.com/forum/viewtopic.php?t=47614
http://www.ccsinfo.com/forum/viewtopic.php?t=46644
RF_Developer
PostPosted: Fri Mar 16, 2012 2:31 am     Reply with quote
Your for loop in MCP_4822_set, which I can't see any real point to, has two things which confuse what's going on.
First is the use of the union. Unions often cause problems as its not easy for us humans to connect one view of it with the others. I try to avoid unions whereever possible. They can be useful in some very occasional cases, but this is not one of them.
The second thing is using macros for gain, dac_enable and sel_dac. It "changes" the apparent functionality, by obscuring its actual function, of bit_set(). Changes it so much so that I went looking for your definition of it in your code.
The result of these is that you are changing the loop variable in the loop in ways that significantly change it. It won't count from 1 to 0xFFF, it will count until any of the bit_set()s change the upper bits and then immediately exit. This is because the word form of the union INCLUDES the bits you are setting in the macros. Is this really what you wanted? I doubt it.
One of the links points to a thread with my code for this part. Take a look at it.
RF Developer
rikotech8
PostPosted: Fri Mar 16, 2012 4:46 am     Reply with quote
I want to increase DAC output voltage from minimum to maximum Vreference. Thats why i used for loop. When i configure setting bits like dac_sel, gain and dac_enable, inside the loop they are not implemented. The shifted out data is only increasing 12data bits from 0x00 to 0xfff and none of 12, 14, and 15 bits occurs.
Thank you!
PostPosted: Fri Mar 16, 2012 4:59 am     Reply with quote
I disagree about the union, the code here is clear, fast and easy to understand.
However agree wholeheartedly about the defines. The problem is that you are changing these bits in the count value, which then means the count will immediately terminate...
Hence the outer loop will then be executed again and again, just sending a count of '0'.
The key would be to separate things:
#define sel_gain_enable (0b1011000000000000)
MCP_4822_set(){
    int16 icount;
    for(icount=0;icount<0xfff;icount++){
      sent.word=icount | sel_gain_enable; // set the three extra bits needed
      delay_ms(10);
This way the number used for the count, is independant of the value being sent.
rikotech8
PostPosted: Fri Mar 16, 2012 11:43 am     Reply with quote
Idea OMG. How couldn't came on my mind about the ORing function.
It's so simple. Thank you very much guys.
