Problem with SPI communication between 16f877a and 30f4011
hoangkhuong
PostPosted: Fri Mar 16, 2012 11:08 am     Reply with quote
Hi everyone,
I am trying to communicate a pic16f877a with a dsPic30f4011 but still failed. I hope some of you can figure out my problem. Thank you in advance.
Here is my code:
For Master (dsPic30f4011)
#include <30F4011.h>
#DEVICE ADC=10
#FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, NOWRT
#FUSES XT_PLL8
#use rs232(baud=4800, parity=N,xmit=PIN_F5,rcv=PIN_F4,bits=8))
#define SDI PIN_F2
#define SDO PIN_F3
#define SCK PIN_F6
#define SS  PIN_B2
#INT_SPI1
void spi()
   clear_interrupt(INT_SPI1);
   int8 a = 8;
   set_tris_b(0x00);
   set_tris_f(0b00000100);
   set_tris_e(0x00);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16|SPI_XMIT_L_TO_H);
   enable_interrupts(INT_SPI1);
   output_high(SCK);
   output_high(SS);
      output_low(SS);
      delay_ms(10);
      spi_write(a);
      output_e(a);
      a++;
      output_high(SS);
      delay_ms(3000);
      if (a >= 200 ) a = 0;
For Slave:
#include <16f877a.h>
#device *=16
#include "LCD_4bit.h"
#define SDI PIN_C4
#define SDO PIN_C5
#define SCK PIN_C3
#define SS  PIN_A5
int8 in_data = 0;
#INT_SSP
void spi()
   in_data = spi_read();
   output_c(in_data);
   lcd_gotoxy(1,1);
   printf(lcd_putc,"%u",in_data);
   clear_interrupt(INT_SSP);
   set_tris_a(0x00100000);
   set_tris_c(0b00010000);
   output_c(0);
   setup_spi(SPI_SLAVE|SPI_L_TO_H|SPI_CLK_DIV_16|SPI_XMIT_L_TO_H);
   enable_interrupts(INT_SSP);
   delay_ms(20);
Thanks again Smile
PostPosted: Fri Mar 16, 2012 12:33 pm     Reply with quote
Here are some SPI slave examples:
This example uses software SPI for the master and
hardware SPI for the slave (all in the same PIC):
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
Here is an example of hardware SPI for master and slave (using 2 PICs
on separate boards):
http://www.ccsinfo.com/forum/viewtopic.php?t=39145
