Invalid Pre-Processor directive Export requires IDE
rovtech
PostPosted: Sat Mar 31, 2012 3:39 pm     Reply with quote
I can’t get it any simpler but I get the error message:
Error 7 "C:\Program Files\PICC\devices\16F722.h" Line 196(2,6): Invalid Pre-Processor directive Export requires IDE
My main program is:
#include <16F722.h>
#fuses INTRC_IO, NOWDT, PUT, NOPROTECT, BROWNOUT, MCLR
#include <ST7920_pb.c>
// Main Function
   while (TRUE)
  glcd_init();            // this represents other programming
//The ST7920_pb.c function I include is:
void glcd_init()
delay_cycles (1);
I have other programs of the same form that work fine. It seems the error is in the 16F722.h file but it works and compiles my other programs. Am I doing something dumb?
PCM and MPLAB on Win XP
PostPosted: Sat Mar 31, 2012 4:24 pm     Reply with quote
See this thread. It may help:
http://www.ccsinfo.com/forum/viewtopic.php?t=46750
rovtech
PostPosted: Sat Mar 31, 2012 5:07 pm     Reply with quote
It basically says I have to 'include' a second .c file, which I have done.
I am doing exactly the same as a working program that uses #include <lcd.c> and which still compiles with no errors or warnings.
PostPosted: Sat Mar 31, 2012 6:04 pm     Reply with quote
Are you "adding" the ST7920_pb.c file to the Project Window in MPLAB,
so that it appears in the list of Source Files ? If so, don't do that.
The only file that should be in the list of Source Files in the Project Window
is the main file in the project. Remove ST7920_pb.c from the Source
Files list. (Select it and press the Del key).
If you want to see ST7920_pb.c in the Project Window, so you can click
on it for easy access, then "add" it to the "Other Files" list in that window.
Then it will compile OK.
rovtech
Problem solved
PostPosted: Sun Apr 01, 2012 7:33 am     Reply with quote
Yes I had both files there.
I just removed the one and it works fine.
Sorry for being so stupid. Embarassed
