need some help Humidity Sensor HS15P
vipeur
PostPosted: Tue Mar 20, 2012 9:19 am     Reply with quote
Hello all,
Is there anyone can give me any information about interfacing the humidity sensor HS15P with the PIC18F2550 and displays the values in the virtual terminal (Proteus Isis+Code) ?
Please help me and thanks in advance.
PostPosted: Tue Mar 20, 2012 2:24 pm     Reply with quote
This is a difficult sensor to use. It doesn't have an easy-to-use digital
interface. Do you have to use this sensor ? Can you use a different one ?
asmboy
PostPosted: Tue Mar 20, 2012 4:53 pm     Reply with quote
I use Honeywell HIH-5030 for monitoring humidity in a biology incubator
along with other simple, voltage based sensors for temperature and CO2 content.
Alternatively, the HIH-5030 works very well with even 10 bit pics but is exceptionally sweet and well resolved with 12Bit models - all you need is a stable 3.3 or 5 v excitation and it can be direct read.
The part you started asking about needs a LOT of analog circuitry to get any use at all.... PCM programmer has given you the straight dope:
I would NEVER set out to use the HS15 UNLESS i was on a no limits budget and had the time to fool with the design which requires at a minimum a stable oscillator circuit and a very linear detector / rectifier circuit.
