msakms
12-hour Mode using the DS1307 |
Posted: Sun Nov 20, 2011 8:01 am |
Greetings folks,
The DS1307 driver provided in CCS Forums works like a charm. Here's the code that I'm referring to:
Code: | ////////////////////////////////////////////////////////////////////////////////
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Disable squarewave output ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec) Set the date/time ///
/// ds1307_get_date(day,mth,year,dow) Get the date ///
/// ds1307_get_time(hr,min,sec) Get the time ///
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); // REG 3
day = bcd2bin(i2c_read() & 0x3f); // REG 4
mth = bcd2bin(i2c_read() & 0x1f); // REG 5
year = bcd2bin(i2c_read(0)); // REG 6
i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f);
min = bcd2bin(i2c_read() & 0x7f);
hr = bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
BYTE temp;
BYTE retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// Input range - 00 to 99.
BYTE temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
Now I'm wondering about how to implement the 12-hour mode?
I know that I've got to set bit-6 of the hours register and I believe I've got to do something with the 0x7F mask value for the hours register, but I had no luck after trying that out.
Looking forward for some enlightenment & Many thanks in advance. |
Posted: Sun Nov 20, 2011 8:31 am |
No, you don't have to change the mask.
When you set the hours, bitwise OR the 32 bit (0x20) with the desired
hour value before setting the time. With bit 6 set you would set/clear
bit 5 to set AM/PM. _________________ Google and Forum Search are some of your best tools!!!! |
danyboy666
Posted: Sat Mar 17, 2012 8:35 pm |
Sorry to bump this tread.
I think i've figured out how to put into 12 hour mode like so:
Code: | #define BIT_VAL(x) (1 << x)
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE ap, BYTE hr, BYTE min, BYTE sec,)
sec &= 0x7F;
hr &= 0x3F;
ap &= 0x3F;
i2c_start();
i2c_write(bin2bcd(hrFinal)); // REG 1
i2c_write(bin2bcd(hr) |= BIT_VAL(6)); // REG 2
i2c_stop();
Now if i want to set/clear the 5th bit from reg 2 i run into some problems.
Code: | i2c_write(bin2bcd(ap) &= BIT_VAL(5)); // REG 2 |
Code: | void ds1307_get_time(BOOLEAN &ap, BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
ap = bcd2bin(i2c_read(0) & 0x1f);
i2c_stop();
Can someone please point me into the right direction? |
