Analog Devices DAC8512 - 12-bit SPI DAC - Example Program
dyeatman
PostPosted: Sun Mar 04, 2012 6:26 pm     Reply with quote
#include <18F4550.h>
////  Example to control a 12 bit DAC8512 Digital to Analog chip        ////
////  using a PIC18F4550                                                ////
////  Written by DYeatman 3/4/2012                                      ////
#FUSES NOWDT                    // No Watch Dog Timer
#FUSES PUT                      // No Power Up Timer
#FUSES NODEBUG                  // No Debug mode
#FUSES MCLR                     // Master Clear
#FUSES INTRC                    // Use internal R/C oscillator
// Mode definitiona
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H) //CPOL=0   CPHA=0
#define SPI_MODE_1  (SPI_L_TO_H)                   //CPOL=0   CPHA=1
#define SPI_MODE_2  (SPI_H_TO_L)                   //CPOL=1   CPHA=0
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H) //CPOL=1   CPHA=1
#use delay(clock=8000000)
// 18F4550 Hardware SPI pins
#define SPI_DO      PIN_A0  // data output
#define SPI_DI      PIN_A1  // data input
#define SPI_CLK     PIN_A2  // clock output
// define control pins
#define SPI_CS      PIN_B2   // enable pin
#define SPI_LD      PIN_B3   // load pin
#define SPI_CLR     PIN_B4   // clear pin
#use spi(DI=SPI_DI, DO=SPI_DO, CLK=SPI_CLK, enable=Pin_A3, BITS=12, mode=3)
void send_data(int16 data)
   output_high(SPI_LD);
   delay_us(5);
   output_low(SPI_CS);  // select the chip
   delay_us(5);
   spi_xfer(Data);          // send the new value to the DAC register
   delay_us(5);
   output_high(SPI_CS); // deselect the SPI data input
   delay_us(5);
   output_low(SPI_LD);  // latch the data transfer to the outputs
   delay_us(5);
void DAC_reset()
    output_low(SPI_CLR);  // reset the DAC
    delay_ms(1);
    output_high(SPI_CLR);
    output_high(SPI_CS);  // de-select the chip
    output_high(SPI_LD);  // set control signals back to inactive
    output_high(SPI_CLK);
     int16 DACoutMV;
     setup_oscillator(OSC_8MHZ | OSC_INTRC);
     setup_adc(no_analogs);
     //  set control signals to their initial states
     output_high(SPI_CLR);  //
     while(1)   // this loop outputs a square wave and triangle wave every 500ms
         DACoutMV= 2000;      // value 0 to 4095 (0xfff) =  0 to 4.095 volts
         send_data(Dacoutmv); // start a square wave 2 volts high
         delay_ms(30);        // make the square wave 30ms long
         DACoutMV= 0;         // set the DAC output back to zero using data
         send_data(Dacoutmv); // end of 30ms square wave
         delay_ms(100);       // wait 100ms before starting triangle wave
         // start of triangle wave
         for(DACOutMV=0x00;DACoutMV<0xfff;DACoutMV++)
         // end of triangle wave
         delay_ms(30); // wait 30ms at the top
         dac_reset();  // reset everything back to zero
         output_toggle(PIN_C1);  // bink LED to indicate end of loop
         delay_ms(500); // wait 500ms before we do it again
Google and Forum Search are some of your best tools!!!!
asmboy
PostPosted: Mon Mar 05, 2012 5:21 pm     Reply with quote
nice code
great imbedded documentation
