Simulation RA4
kamillas
Simulation RA4
PostPosted: Wed Feb 29, 2012 4:00 am     Reply with quote
I want to know why in the simulation if I sent:
output_A(0b111111);
Proteus simulation gives me high impedance in the pin RA4.
RF_Developer
Re: Simulation RA4
PostPosted: Wed Feb 29, 2012 4:22 am     Reply with quote
kamillas wrote:
output_A(0b111111);
Pin RA4 is an open drain output on some (maybe many PICs). It cannot force the pin to high, you have to have a pull-up. Check this on the data sheet for your PIC.
RF Developer
kamillas
PostPosted: Wed Feb 29, 2012 4:50 am     Reply with quote
thank's Rf developer
PostPosted: Wed Feb 29, 2012 6:29 am     Reply with quote
WOW !!! Proteus got something RIGHT???????
RF_Developer
PostPosted: Wed Feb 29, 2012 7:12 am     Reply with quote
Maybe not. I might be standing by a lamppost in a frozen forest....
RF Developer
PostPosted: Wed Feb 29, 2012 7:45 am     Reply with quote
The silly thing is that the basic analog simulator on Proteus is very good. Where is has problems is in complex digital parts. Simple things like a transistor output, it'll usually get right.
There is a separate issue, down to how you use it, that it will automatically make connections to things like power pins, and then not show these. If you look at their examples, they deliberately put labelled pins showing these connections, while 'casual' users tend to omit these. Hence people following the circuit that results then omit these connections.
For what most people want a simulator for, it's digital handling of parts like the PIC's, is 'inadequate'. MPLAB is far more accurate, but harder to use.
I hate it, and believe it causes more problems than it ever solves, but don't expect basic things like this to not work.
