PIC24F16KA102 SPI
cinginanewlight
PIC24F16KA102 SPI
PostPosted: Wed Feb 29, 2012 6:33 am     Reply with quote
I'm new to PIC's and I am probably missing something very simple, but I can't get the h/w SPI to work.
The serial clock pin is pulled high and the data pin stays low.
My code is as follows, I've loaded it into two24F16KA102's, and I am using a scope to view the IC pins.
#include <24F16KA102.h>
// compiler v4.120
#device ICD=TRUE
#fuses MCLR,NOWDT,NOPROTECT,NOBROWNOUT,HS
#use delay (clock=4M)
void main() {
/* while (true) {
   output_toggle (PIN_B10); // check port h/w works- OK squarewaves can be seen
   output_toggle (PIN_B11); // tried another chip too!
   delay_ms(20);
// setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
while (true)
   spi_write (0xFF);       // RB10 sclk is pulled high
   delay_ms(500);          // RB11 sdata is 0V
   spi_write (0x00);
   output_toggle(PIN_A4); //heartbeat LED OK!
Any suggestions and help for a newbie will be gladly received.
