MRF24J40MA Security issue
goranst
PostPosted: Tue Feb 28, 2012 5:35 pm     Reply with quote
Hi all.
I am working on a universal home automation board base on pic 18f14k50 and MRF24J40MA. The communication works like a charm, I have no problems.
Anyway, when I try to encrypt the messages, It simply does not work.
I follow the MRF24J40MA data sheet and implement all the necessary steps. This is my TX_normal routine:
void write_TX_normal_FIFO(void){
   int i = 0;
int8 temp;
   data_TX_normal_FIFO[0]  = HEADER_LENGHT;
   data_TX_normal_FIFO[1]  = HEADER_LENGHT + DATA_LENGHT;
   data_TX_normal_FIFO[2]  = 0x01;                        // control frame
   data_TX_normal_FIFO[3]  = 0x88;
   //data_TX_normal_FIFO[4]  = SEQ_NUMBER;                // sequence number
   data_TX_normal_FIFO[5]  = PAN_ID_2[1];                 // destinatoin pan
   data_TX_normal_FIFO[6]  = PAN_ID_2[0];
   data_TX_normal_FIFO[7]  = ADDRESS_short_2[0];          // destination address
   data_TX_normal_FIFO[8]  = ADDRESS_short_2[1];
   data_TX_normal_FIFO[9]  = PAN_ID_1[0];                 // source pan
   data_TX_normal_FIFO[10] = PAN_ID_1[1];
   data_TX_normal_FIFO[11] = ADDRESS_short_1[0];          // source address
   data_TX_normal_FIFO[12] = ADDRESS_short_1[1];
   data_TX_normal_FIFO[13] = DATA_TX[0];                  // data
   data_TX_normal_FIFO[14] = DATA_TX[1];
   data_TX_normal_FIFO[15] = DATA_TX[2];
   data_TX_normal_FIFO[16] = DATA_TX[3];
   data_TX_normal_FIFO[17] = DATA_TX[4];
   data_TX_normal_FIFO[18] = DATA_TX[5];
   data_TX_normal_FIFO[19] = DATA_TX[6];
   data_TX_normal_FIFO[20] = DATA_TX[7];
   for(i = 0; i < (HEADER_LENGHT + DATA_LENGHT + 2); i++)
    write_ZIGBEE_long(address_TX_normal_FIFO + i, data_TX_normal_FIFO[i]); // write frame into normal FIFO
//2.
   for(i = 0; i < 13; i++)
    write_ZIGBEE_long(UPNONCE0+i, NONCEkey[i]); // write NONCE security key normal FIFO
//3.
   for(i = 0; i < 16; i++)
    write_ZIGBEE_long(SECKTXNFIFO + i, key[i]); // write security key normal FIFO
//3.
  temp = read_ZIGBEE_short(SECCON0);
  temp = temp | 0x05;
  temp = temp & 0xFD;
  write_ZIGBEE_short(SECCON0, temp);   // write Security Suite (AES-CBC-MAC-128)
//4.
  write_ZIGBEE_short(SECCR2, read_ZIGBEE_short(SECCR2)|0x40);
  //5.
  temp = read_ZIGBEE_short(TXNCON);
  temp = temp | 0x02;                   // mask for set encrypt
  write_ZIGBEE_short(TXNCON, temp);
  //6.
  temp = temp | 0x01;                // mask for start transmit
Did someone had similar problems? has someone developed a encryption routine that is tested and works?
Thanks for the help in advance
Goran Stojanovski
www.atronika.com
