Problem using CCP1
marcus.couceiro
Problem using CCP1
PostPosted: Mon Feb 20, 2012 7:55 pm     Reply with quote
Gentlemen,
I am trying to measure the period of a known frequency using the following code
#include <16F873.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT                      //Power Up Timer
int1 interruption=0;
#int_CCP1
   void CCP1_interruption()
         interruption=1;
   long timer_T1, timer_T2, period;
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   set_timer1(0);
   setup_ccp1(CCP_CAPTURE_RE);
   setup_ccp2(CCP_OFF);
   enable_interrupts(INT_CCP1);
   clear_interrupt(INT_CCP1);
         if (interruption==1)
               disable_interrupts(GLOBAL);
               timer_T1 = CCP_1;
               period = timer_T1-timer_T2;
               timer_T2 = timer_T1;
               interruption=0;
       putc(254);putc(1); delay_ms(10);
       printf("period: %lu", period);
So far my display gives only 0.0 as readings. Could anyone tell what am I doing wrong?
Thanks,
Marcus Couceiro
PostPosted: Mon Feb 20, 2012 8:49 pm     Reply with quote
Do a search on the forum for: tachometer
http://www.ccsinfo.com/forum/search.php
There are several threads with working CCP capture code.
Stygian
PostPosted: Mon Feb 27, 2012 8:56 am     Reply with quote
Hello All!
I don't want to open a new topic so I write here.
My question is simple. I'm using a PIC16F1938.
I want to use the CCP3 and the RS232 at the same time.
How can I disable the CCP3 on port C6 and enable on port B5 Rolling Eyes ?
Best regards,
Stygian
