10F222 and PICKit 2 : Don't program the PIC
PFUM
PostPosted: Thu Feb 23, 2012 10:31 am     Reply with quote
Hi to all,
I can't program a PIC 10F222 with the PICKit 2. The program is very simple, it makes just a led flash.
I believe that it is in technical trick.
My HW is very simple.
Only one led pin GP2 and One led pin GP3. Put Pull-Up (4k7) on the pin 8.
My little board is connected by the 6 points connector of the PicKit 2.
The program is generated with CCS last version. Thank you for your help because I found nothing on the forum about this problem.
Best regards.
The C Code by CCS :
#include <main-new-10F222.h>
   //Example blinking LED program
   while(true)
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
#include <10F222.h>
#device adc=8
#FUSES
#use delay(clock=8000000)
#define LED PIN_B2
#define DELAY 1000
PostPosted: Thu Feb 23, 2012 1:33 pm     Reply with quote
What is the source for the 8,000,000 Hz clock ?
You have not chosen one according to your FUSES options.
Also are you saying the PICkit doesn't program the PIC or that the PIC doesn't run your program the way you think it should ???
PFUM
PostPosted: Thu Feb 23, 2012 1:46 pm     Reply with quote
I use internal clock.
Ok for the definition of the fuses, but i don't define with ccs this fuses.
Could you indicate me the typical fuses configuration?
Thanks for your help.
PostPosted: Thu Feb 23, 2012 2:41 pm     Reply with quote
Use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Do a search for 10F222. You will find several demonstration programs.
Most of them are from me. They will show you how to setup the #fuses
and anything else you need for that PIC.
