Connect lcd 2x16 with the same port of keyboard 4x4(portb)
koko87
PostPosted: Thu Mar 08, 2012 5:06 am     Reply with quote
Hi everybody, I'm a newbie in microcontroller and I have used the flex driver for my 4x4 keyboard but i want to connect my lcd 2x16 in the same port b with the keyboard. How can i do this ? Please help friends, I need it for my school project. Thanks for your interest Smile and if you can show me the schematic how can I do that, thanks a lot Smile I forget to say I'm using pic16F876. Thanks for helping ...
PostPosted: Thu Mar 08, 2012 6:38 am     Reply with quote
everything you need, CCS kindly supplies......look in the EXAMPLES folder.
hint... for the LCD , look for a file with LCD in it...
hint... for the KPD, look for a file with KPD in it....
hint... when your propject is open, press F11....
koko87
PostPosted: Thu Mar 08, 2012 6:46 am     Reply with quote
Thanks temtronic
I know how to use the functions of keyboard and lcd and i make examples of it with lcd and keyboard separated. But when i want to use the same port its not working. I don't know why. I use keyboard 4x4 in port b and I want to use the same port b to run my lcd. How can i do that ? Thanks temtronic for helping me and thanks for your interest.
PostPosted: Thu Mar 08, 2012 8:53 am     Reply with quote
Not easy to do.
Realistically, it is possible, by adding two 2-4 line decoder/multiplexors, fed from the four data lines to the LCD, with the keyboard matrix fed from these, and the output from one feeding the unused bit in the bottom of the port. Then when the LCD is not being written to (EN not selected), you can put a key number onto the high four lines, and test the input to see if this selected key is on/off.
Without extra hardware like this, I don't think it is possible.
PostPosted: Thu Mar 08, 2012 12:27 pm     Reply with quote
See this post. It uses the CCS keypad and lcd drivers, not the flex drivers:
http://www.ccsinfo.com/forum/viewtopic.php?t=26229&start=2
PostPosted: Thu Mar 08, 2012 4:02 pm     Reply with quote
Problem is that if you hold a combination of keys down while the LCD is actually updating, the display will be incorrect.
May not be likely, or matter, but for me this makes it unusable.
koko87
PostPosted: Thu Mar 08, 2012 6:41 pm     Reply with quote
Thanks all of you, but it seems that i have no solution to do it and I'm obliged to use another port but one question. Why when i use the flexible lcd driver 2x16 with port A of my pic16F876 he don't work!!! But when i use the port C he work fine. Any ideas!!! Should i have to add something or what ? Thanks friends for helping Smile, im using my lcd 2x16 in port b with thr originale lcd driver lcd.c the probleme that i want to change juste the three pins E,rs,rw to the pin_A0,pin_A1,pin_A2,how can i do that and what change i have to do it to the lcd.c to get work thanks a lot for you interresting frinds thanksssss Smile and thanks for your time to answer and helping me Smile
PostPosted: Fri Mar 09, 2012 2:51 am     Reply with quote
Help if you said 'what chip'. However odds are you are using one where port A wakes up setup for analog.
Use flex_lcd, rather than lcd.c. This allows the pins to be anywhere. Smile
Mike Walne
Port A
PostPosted: Fri Mar 09, 2012 4:47 am     Reply with quote
Again without telling us which PIC, you're making it difficult for us to help. Read the CCS forum guide.
As well as Ttelmah's hint. On many PICs RA4 is open drain. If you are connecting data bits to RA4/5/6/7, then A4 won't pull up!
Mike
koko87
PostPosted: Fri Mar 09, 2012 6:32 am     Reply with quote
thanks , im using pic16F876 and i have branched the lcd to port b and using lcd.c not flexible driver then i branched my keyboard 4x4 in port b and c im looking for use the port A for my lcd 2x16 ,and when i use the flexible lcd is not work if use them with the port b or c or a he said combination logic problem ?any ideas thanks
PostPosted: Fri Mar 09, 2012 7:08 am     Reply with quote
You've got to read the datasheet and understand what it says.
Some pins on PortA may not be suitable for your project.You have to check and make sure that the pins you select are good for your design.Do you need a pin to be just an output, an input or both ? On epin RA4 is open drain, all have 'other uses' and those 'uses' must be disabled.
Mike,Mr T and others will help you but you have to read and comprehend the basic operation of the PIC.
Generally speaking PORTB is the easiest 8bit I/O port for LCD/KPD use.If available, I'd use it for 'my first project'.
koko87
PostPosted: Fri Mar 09, 2012 7:24 am     Reply with quote
you are right temtronic thank you and thanks for Mike Walne,Ttelmah,PCM programmer, i will see again the datasheet may be i miss something that i don't see it ;) thanks all of you i know you will help me it the famous forums thanks.
