Dividing a 32bit floating number into (4) 8-bit integers for
Posted: Tue May 13, 2003 5:46 am
I have a few 32bit floating numbers which I want to use to send to an EEPROM for storage. Does anyone have an idea of how to break this 32bit floating number into 4 separate 8-bit integers???
The make8() function only works on integers and does work with floating point numbers.
liche
___________________________
Original Post ID: 14400
Tomi Guest
Re: Dividing a 32bit floating number into (4) 8-bit integers
Posted: Tue May 13, 2003 6:37 am
See CCS FAQ "How do I write variables to EEPROM that are not a byte?" That example is about saving floats.
:=I have a few 32bit floating numbers which I want to use to send to an EEPROM for storage. Does anyone have an idea of how to break this 32bit floating number into 4 separate 8-bit integers???
:=The make8() function only works on integers and does work with floating point numbers.
:=Thanks
:=liche
Original Post ID: 14403
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Tue May 13, 2003 6:39 am
Here's the answer to your question:
<a href="http://www.ccsinfo.com/faq/?24" TARGET="_blank">http://www.ccsinfo.com/faq/?24</a>
