Error on "printf" by using int16
Jent
PostPosted: Wed Feb 15, 2012 10:06 am     Reply with quote
Hi.
I have a little problem I'm not able to solve on the coding. Hope the experts here can help me.
Below is my one part of coding:
   int16 heading;
   while(true)
      heading=(HMC6352_read_heading())/10;
      lcd_init();
      printf(lcd_putc, "\fHeading degree:");
      printf(lcd_putc, "\n       %1u\r", heading);
However, the problem exists on the "printf"----> Printf format type is invalid. But I really need to use 16bit, so i used int16. Anyone can help me please.
PostPosted: Wed Feb 15, 2012 10:21 am     Reply with quote
If you press F11 when your project is open, the CCS onscreen Help files come up...locate the 'functions' and scroll down to printf..... it'll show you what you need to know...
I think you've mistyped the required format for an Int16.
lower case 'L's and 1s look very much the same depending on the font .
Jent
PostPosted: Wed Feb 15, 2012 10:57 am     Reply with quote
Thanks informing...i really mistyped with 1 but actually is l...
actually I followed the previous post message from this ccs forum, and also intend to try this testing..
actually i did not really understand regarding this part:
printf(lcd_putc, "\n       %lu\r", heading);
if %u is regarding to unsigned decimal integer, but for %lu, i really couldn't understand. I checked the ccs manual, but discovered nothing..
PostPosted: Wed Feb 15, 2012 1:03 pm     Reply with quote
Open CCS Help ( press F11) when project is open...
Goto Contents....
Open Data Definitions...
Open Basic Types.....
read what are the various types of data...
then
Goto Contents...
Open Built-in Functions...
Open All Built-in Functions...
Open printf()....
read.......
You should be able to see that an Unsigned INTeger is a value represented by 8 bits( a BYTE) of 0 to 255.
INT16 means a 16 bit integer( 2 bytes, a WORD in my world....).If Unsigned, 0 to 65535.
A Long Unsigned(Lu) can represent 0 to 65535, 16 bits of data, no negative numbers allowed.
