How to find distance between two WSN nodes (for nRF24L01)
hikaan
PostPosted: Fri Jan 27, 2012 8:24 pm     Reply with quote
Hi
I am using nrf24L01 transceiver in my WSN node. In this transceiver there is no support for RSSI. In this case, is there any method to find the distance between two WSN nodes ? Is there any scheme like TOF (Time of Flight) that will be useful or not ? Pls suggest your opinion.
G Kannan
PostPosted: Sat Jan 28, 2012 2:12 pm     Reply with quote
You probably will not get any responses with a solution( there are 3 that I know) unless you report which PIC type and compiler version you are using as well as application(home,office, school), accuracy of distance( 1ft, 1mm, ??),update rate(1 hr, 1 sec,1ms,??).
Eduardo__
PostPosted: Fri Feb 03, 2012 10:55 am     Reply with quote
Dear folks. I´m looking for the same solution. Do you know whether is possible to do this with RF? like an LPS(Local positioning system)?
My needs are:
application(home or school), accuracy of distance(1inch or less),update rate(100ms or better).
I was looking on ultrasound solutions as I cannot think nothing faster enough for reading a RF signal time of flight(should be faster enough for read differences of pico-seconds). Even GPS system uses atomic clocks and it have meters of precision.
Anyone have ideas?
Thanks a lot!!!!
Eduardo Guilherme Brandt
PostPosted: Fri Feb 03, 2012 1:01 pm     Reply with quote
Several solutions all based upon specs and money you can afford for the project.
How much money will you spend ?
Simple GPS can give you 1" resolution at 1/10th second update rate.
Eduardo__
PostPosted: Fri Feb 03, 2012 1:40 pm     Reply with quote
But, how to achieve GPS 1" resolution?
Of course, despite of how much money we have, I would like to know your ideas, if possible.
Every solution must be as cheap as possible, but I know it´s not possible.
I cannot understand how GPS receivers can manage so tinny time differences. I know that pico or even nano-second times are problematic for uCs and even uPs. Do you know how this works on this problem?
PostPosted: Fri Feb 03, 2012 1:57 pm     Reply with quote
The basic solution involves using multiple GPS units per 'device'. Using 8 it is easy to get 1" resolution.
It's up to you to buy 8 identical GPSes,get all 8 talking to one PIC (faster is better) and do the code to figure out exactly where the device is.
It's not really 'rocket science' just looking at the problem from another 'angle'. When access to milsat gpses was blocked, using comsat gpses required 'outside the box' thinking.
You haven't given details as to the area or range the device has to be found in (room, house, 5 acres, 100 acres), line of sight or rough terrain, weather conditions, speed of target, etc. All are factors in a project like this.
If this is to be in say a 20 x 20' room, one level, simple LADAR will work, easily <1"
Eduardo__
PostPosted: Fri Feb 03, 2012 5:07 pm     Reply with quote
Dear Mr. Temtronic.
Thanks for sharing with us.
It´s a good Idea to buy 8 gps(it´s not expensive, U$30,00 each). But I not understood the principle of operation. Each of 8 gps will give me an approximation. What to do with each gps data(Latitude, longitude, height)? Make an average?
I´ve heard about DGPS system. DO you know how it exactly works?
About LADAR, are you talking of lasers?
Eduardo__
PostPosted: Fri Feb 03, 2012 5:39 pm     Reply with quote
If I understood, LADAR seems to be a better system to see depth. To build a 3D from images.
Eduardo__
PostPosted: Fri Feb 03, 2012 5:43 pm     Reply with quote
What are MILSAT and COMSAT? I´ve not understood this part.
PostPosted: Fri Feb 03, 2012 6:51 pm     Reply with quote
MILSAT ( aka military GPS satellites)
COMSAT (aka commercial GPS satellites).
Eduardo__
PostPosted: Mon Feb 06, 2012 9:48 am     Reply with quote
Dear Mr. Temtronic.
SherpaDoug
PostPosted: Mon Feb 06, 2012 10:04 am     Reply with quote
Would like to know more of how this works. Can you post a link to an explanation? Is it statistical manipulation? Can the 8 GPS modules share a single antenna? Do you need to force the 8 to use the same satellites?
