I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
___________________________
Original Post ID: 10422
john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
Re: array or string use
Posted: Sun Jan 05, 2003 1:26 pm
:=I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
Check out th CCS F.A.Q. on their page. They have an example for floating pt numbers which seems to me would be "easy" to covert to your purposes.
Good luck!
Original Post ID: 10431
RTURNPAUGH Guest
Posted: Sun Jan 05, 2003 5:12 pm
:=:=I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
:=Check out th CCS F.A.Q. on their page. They have an example for floating pt numbers which seems to me would be "easy" to covert to your purposes.
:=Good luck!
:=Thanks for the info. That's exactly what I was looking for.
Original Post ID: 10438
