I'm doing a project (midi controller) that has 74165's in it. The code is supposed to send a code when a button states changes at the inputs of the 74165's.
74165 are well defined and wired correctly. I have 2 of them.
Problem is that it gives a state change in the code when there is none. Could there be something wrong with a bit mask ?
State change on one port:
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
2100793 1 -- 144 7 0 1 G -1 Note Off
2100794 1 -- 144 11 1 1 B -1 Note On
2100795 1 -- 144 12 1 1 C 0 Note On
2100796 1 -- 144 13 1 1 C# 0 Note On
2100797 1 -- 144 14 1 1 D 0 Note On
2100798 1 -- 144 15 1 1 Eb 0 Note On
2101341 1 -- 144 6 1 1 F#-1 Note On
2101342 1 -- 144 11 1 1 B -1 Note On
2101343 1 -- 144 12 1 1 C 0 Note On
2101344 1 -- 144 13 1 1 C# 0 Note On
2101345 1 -- 144 14 1 1 D 0 Note On
2101346 1 -- 144 15 1 1 Eb 0 Note On
Mike Walne
74165 circuit
Posted: Tue Jan 17, 2012 9:10 am
You've not given me enough information.
I know it may seem silly but, can you provide a schematic of your 74165 arrangement, an indication of cable lengths to the 74165's, and just enough compilable code to reproduce the problem.
[I'm assuming you've got plenty of ceramic caps across supply rails.]
