Hardware PWM "Pin RB3"
kbruin79
PostPosted: Tue Jan 17, 2012 11:45 am     Reply with quote
I am using CCS version 4.106 and I would like to set a PWM output at pin RB3 on PIC16F727. After I followed the instruction to setup the pwm on The PIC datasheet under section 15.3.8 then setup the APFCON register to steer the pwm to pin RB3 I wasn't able to see any pwm on that pin.
The same code worked for RC2 (PWM1)
Any help will be appreciated. Here is the code:
//function prototypes:
void make_portb_pins_digital(void);
void init_pwm2(void);
void pwm2(int16 a2d);
// Main
   //MAKE RB3 DIGITAL OUTPUT
   make_portb_pins_digital();
   //INITIALISE PWM2
   init_pwm2();
   //SEND PWM ON RB3
   pwm2(50);
   //DO NOTHING
   //GET THE BYTE ADDRESS OF PORTA AND B
   #byte ANSELB = getenv("SFR:ANSELB")
   #bit ANSELB_3=ANSELB.3
   //make selected pins on port B digital
   //MAKE PIN RB3 DIGITAL :PWM OUTPUT
   ANSELB_3=0;
   //Assign pwm2 to RB3
   //Disable the PWM pin (CCPx) output driver(s) by
   //setting the associated TRIS bit(s).
   TRISIOB_3=1;
   //Load the PR2 register with the PWM period value.
   PR2=40;              // 3000hz
   //Configure the CCP module for the PWM mode
   //by loading the CCPxCON register with the
   //appropriate values.
   CCP2CON=0b00001100;   // Set CCP2 PWM active high
   //Load the CCPRxL register and the DCxBx bits of
   //the CCPxCON register, with the PWM duty cycle
   //value.
   duty = 0;               // set duty cycle to 0
   CCP2CON_4 = duty_0;     // Store duty to registers as
   CCP2CON_5 = duty_1;     // a 10-bit word
   //store the eight MSbs in CCPR1L.
   CCPR2L = duty >> 2;     // store the remaining low byte
   //clear the TMR21F interrupt flag bit of PIR1 register
   PIR1_1=0;
   //Configure the T2CKPS bits of the T2CON
   //register with the Timer2 prescale value.
   //and
   //Enable Timer2 by setting the TMR2ON bit of
   //the T2CON register.
   T2CON=0b00000111;
   //Wait until Timer2 overflows, TMR2IF bit of the
   //PIR1 register is set.
   wait_for_TMR2IF:
   if (PIR1_1 == 0)
     goto wait_for_TMR2IF;
   //enable PWM by setting pin to output
   TRISIOB_3=0;
   APFCON_0=1;
   duty=a2d;
   CCPR2L = duty >> 2;    // store the remaining low byte}
PostPosted: Tue Jan 17, 2012 12:01 pm     Reply with quote
Well you could make your life and anyone trying to read your program a LOT easier by using the CCS builtin functions !!
I got 'lost' about 1/3 down and gave up. Too much reading for such a simple program.
kbruin79
PostPosted: Tue Jan 17, 2012 12:19 pm     Reply with quote
temtronic wrote:
Well you could make your life and anyone trying to read your program a LOT easier by using the CCS built-in functions !!
I Simplified as much as possible, assume all constants, variables are defined. I will eventually use the built-in function but I would like to know why the code isn't working.
PostPosted: Tue Jan 17, 2012 5:16 pm     Reply with quote
you SAY you are using CCS but you are not-- it looks more like the structure of one of the crummy register oriented C's like HT or S-boost or Mikro...
for example, this mess for init of pwm2 mode and duty cycle :
APFCON_0=1;
COULD be WAY better handled by a #FUSE STATEMENT for the part in question --
then this approximate reduction
void init_pwm2(void) {
  // do the proper  setup_timer2(...); FIRST
   set_pwm2_duty(0);  // i do this BEFORE the setup enable
  setup_ccp2(ccp_PWM);
 // DONE
THEN THIS!!!
is really the same as the CCS function
set_pwm2_duty();
this looks like falling back on assembler in HiTECH C - or one of the other really poor C for PIC compilers - this register defined - manipulation is NOT the CCS way at all, IHMO.
why not use the powerful C constructs CCS offers ??
perhaps you will get results if you READ the CCS manual
and try it their way next Very Happy Very Happy Arrow
