PIC 18f4525 and pin B3 digital input
FMOpt2000
PostPosted: Mon Jan 09, 2012 10:00 am     Reply with quote
Hi, I'm new in using PIC.
I did a firmware without problems but now I re-assigned my PINs
and I've a strange behaviour on pin B3 (pin 11 - tqfp)
I've some pulse in output (1ms) 500 ms(period), but for me this is a digital input.
Do you help me, about that?
This is the code (without some parts).
#include <18F4525.h>
#device ICD=TRUE
#device adc=10
#FUSES WDT128
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
//#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTD                     //Data EEPROM not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#use delay(clock=8000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
#include "main.h"
#include "functions.c"
// sezione debug da togliere alla fine
int1     app_debug=0;
int1     onda;
#int_RTCC
void  RTCC_isr(void)
   setup_adc_ports(AN0_TO_AN2|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_6);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   //setup_timer_0(RTCC_INTERNAL);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //disable_interrupts(INT_RTCC);
   enable_interrupts(INT_RTCC);
   //setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_31250|OSC_PLL_OFF);  //OLD
   setup_oscillator(OSC_8MHZ);  //reccomended
   // TODO: USER CODE!!
   general_status[0]=0xFF;
 // CODE
PostPosted: Mon Jan 09, 2012 1:13 pm     Reply with quote
Will this code that you posted actually show the problem if we program it
into a PIC ? If not, post a complete program (but very short) that does
show the problem.
