Dynamic Matrix
Engeletrica
Dynamic Matrix
PostPosted: Wed Jan 11, 2012 5:47 am     Reply with quote
Hello Everyone!!
I need construct a matrix where the values are dynamic.
For example:
{a b c
  e f g}
Where, a,b,c,d,e ,f e g are variables and can be modified for users.
Somebody can help me?
I put piece of my code in order easily help.
int a,b,c,d,e,f;
a=50;
b=20;
c=40;
d=30;
e=90;
f=70;
av[0]=a;
av[1]=b;
av[2]=c;
av[3]=d;
av[4]=e;
av[5]=f;
while(true)
long const rotacao [2][6]={{ 0  ,  40 ,  80 ,  120 , 160 ,  200 }
                                             {av[0];av[1];av[2];av[3];av[4];av[5]}};
signed long rot_min=0;
signed long rot_max=0;
signed long av_min=0;
signed long av_max=0;
signed long z=0;
signed long z1=0;
signed long z2=0;
signed long c1=0;
signed long c2=0;
set_tris_a(0b00001000);
set_adc_channel(3);
xa=read_adc();
for (j=0;j<=6;j++)
      rot_min=rotacao[j];
      //rot_max=rotacao[i+1];
      if(xa>=rot_min)
         rot_max=rotacao [j+1];
         if(xa<=rot_max)
            av_min=av [j];
            av_max =av [j+1];
            c1=av_max-av_min;
            c2=rot_max-rot_min;
            z=c1/c2;
            //z=(long)((av_max-av_min)/(rot_max-rot_min));
            z1=av_min-z*rot_min;
            z2=(long int)((z*xa)+z1);
Sorry, my mistakes in english.
asmboy
PostPosted: Wed Jan 11, 2012 3:01 pm     Reply with quote
perhaps you would like to show a more complete program -
that actually COMPILES??
Brandon03
PostPosted: Thu Jan 12, 2012 12:14 am     Reply with quote
There are two common approaches. For N rows with M columns each:
One is to simulate the matrix with a one-dimensional array. You
allocate space for N*M objects, as with
T *ptr = malloc(N * M * sizeof *ptr);
and you reference the (i,j)th element by calculating the appropriate
subscript yourself, as in
ptr[i*M+j] = 0;
The other is to build an array of pointers, each pointing to one
row of the matrix, as in
T **ptr = malloc(N * sizeof *ptr);
for (k = 0; k < N; k++)
ptr[k] = malloc(M * sizeof *ptr[k]);
and you reference the (i,j)th element using the natural syntax, as in
ptr[i][j] = 0;
In either case, you pass the array to a function by using the ptr
variable. Note, since N and M are not known until run time:
Using the first approach always requires M to be available to the
function.
In either approach, the function will need both N and M if it is
concerned in any way with the top or right boundary elements of the
matrix.
The second approach is more flexible in that it can handle jagged
arrays where M is not constant for each row.
<<Remove the del for email>>
