why Pic16f877a UART send unknown characters
Goto page 1, 2  Next
cse307
PostPosted: Tue Dec 27, 2011 4:23 pm     Reply with quote
Q1:
I programed my pic16f877a to send a serial data (information about my project ) to my PC but the Hyper terminal receives unknown symbols -infinitely - and when I touch it it changes the symbols.(weird Exclamation Question ) There is no short circuit. I tested the board on another PIC16f with different code and using DMM.
Baud rate:9600 on PC and PIC16f(4MHz)
Q2:
I connected a cellphone which supports AT commands to PC and tried "AT" and i received"OK", its working good. But when I use it with PIC16 (send "AT"), the PIC16 does not receive anything from the cellphone. I tried to send "AT" using PIC16 and receive it using PC. I received "OK". The code on the PIC16 to send "AT" and receive "OK" is tested using Bluetooth and it works.
I put an LED on the cellphone (Rx) so when PIC16 send "AT" the LED blinks.
SherpaDoug
PostPosted: Tue Dec 27, 2011 4:28 pm     Reply with quote
If the circuit behavior changes when you touch it, the first place I would look is for a bad GROUND connection.
cse307
PostPosted: Wed Dec 28, 2011 2:34 pm     Reply with quote
But I checked the circuit on the board on another pic with different code that also uses the rs232 and it worked good with no problem. And I reprogrammed the PIC (that worked) with the same code in previous PIC(have problem) but the problem still existed.
ALPL
RS232 misbehaviour
PostPosted: Thu Dec 29, 2011 5:21 am     Reply with quote
Next to a possible GND-problem you may not have put a 0.1µF capacitor between Vdd and Vss or the MCLR-pin is not connected/set properly.
ALPL
PostPosted: Thu Dec 29, 2011 5:41 am     Reply with quote
Q2: which cellphone do you use? Did you check the cell-phone serial communication parameters/protocol, esp the electrical levels of the comm-lines and the hand-shake protocols?
cse307
Re: RS232 misbehaviour
PostPosted: Fri Dec 30, 2011 8:00 am     Reply with quote
the MCLR-pin connected correctly i test it But i did not put a 0.1uF cap is it important??
cse307
PostPosted: Fri Dec 30, 2011 8:04 am     Reply with quote
the Cell phone is T68i Sony Ericsson and i don't think that there is any protocols becauunication and it works on computer RS232 and it respond to PIC commands But PIC cannot receive reply's while computer can
ALPL
PostPosted: Fri Dec 30, 2011 10:25 am     Reply with quote
Better try with the 0.1µF capacitor.
ALPL
PostPosted: Fri Dec 30, 2011 10:28 am     Reply with quote
If you have an oscilloscope you may trace the response of the cell-phone to see if anything is coming back and how it looks like.
PostPosted: Fri Dec 30, 2011 10:51 am     Reply with quote
So you are able to connect the phone to a PC directly?.
So, how are you connecting to the PIC?. You are aware that you _need_ an inverting RS232 buffer between the PIC and the phone, if the phone can talk directly to a PC?....
cse307
PostPosted: Fri Dec 30, 2011 3:50 pm     Reply with quote
Not directly, I used Max232 between computer and cellphone.
PostPosted: Fri Dec 30, 2011 4:03 pm     Reply with quote
OK. Good.
Now, have you tested that this is working correctly?.
There was a several entry thread only a few days ago, where one pin of the MAX232, was not correctly connected, and the poster was having problems with corrupted characters.
cse307
PostPosted: Sat Dec 31, 2011 9:00 am     Reply with quote
i put the Cap between Vcc and Ground?
i will try it when i have one.
thanks for helping me
cse307
PostPosted: Sat Dec 31, 2011 9:09 am     Reply with quote
no i don't have one but if the computer can get the response the PIC16f877a should can i even put a Max232 between the PIC16 and the cellphone but nothing happened.
--for cellphone connected to Max232 on (Tx>pin11(not working) ,Rx directly connected to Tx of PIC(works))
--for PIC (Rx>pin14 of Max232)
cse307
PostPosted: Sat Dec 31, 2011 9:15 am     Reply with quote
Ttelmah wrote:
OK. Good.
onnected correctly.and works correctly when the cellphone connected to computer via MAX.
what is the Pin number that was not connected correctly?Do you Have a link of that thread?.
Goto page 1, 2  Next
Page 1 of 2
