Labjac
| Decision making on serial character |
Posted: Sun Dec 25, 2011 5:51 am |
Hi
Hope all are well, and enjoying Christmas day.
I got a problem again with reading and making decisions on the result, this could be a issue with my C-coding again (Still new), but the code executes fine every second time, when I press the Input (In1) button the first cycle the code executes without waiting at the getc part of the code, the second time it waits, I understand something about debounce but surely the code should sit and wait at the getc() till a character has been entered?
Also when the getc() part executes does it actually clear the buffer or must I manually clear this after the getc() command.
There was also mentioned that I must make use of ISR can somebody please send me an example code of how this works of even a link that I can read more about this...
Please find code below: (Hope I'm using the Code button correctly this time :-)))
| Code: | #use delay(clock=8M)
#use rs232(baud=9600,xmit=PIN_B7,rcv=PIN_B5,bits=8,ERRORS)
#define In1 PIN_C0
#define Op1 PIN_C1
// char cbuffer[24];
// char look_for[]="Word";
char c[24];
char delim[]=",";
char start[]="+";
char stop[]=".";
setup_port_a(sAN2);
setup_adc( ADC_CLOCK_DIV_16 );
If (Input(In1) == 1)
printf("Enter a character: \n");
c[0]=getc();
//printf("The character is %c\n",c);
If (c=='2')
output_high (Op1);
Printf("The character is correct %c\n\r",c);
output_low (Op1);
else if (c=='3')
output_high (Op1);
delay_ms(2000);
output_low (Op1);
Printf("The character is %c\n\r",c);
Printf("This is not a valid character");
Regards,
Labjac |
Joined: 01 Jul 2010 Posts: 9627 Location: Greensville,Ontario
Posted: Sun Dec 25, 2011 6:53 am |
1) please stae which PIC you're using. Usually it's the first line of code.
2) In the examples folder, CCS supplies lots of code including one called ex_sisr.c. That is the EXample of the Serial ISR.
3) EVERYTIME the PIC is in a 'delay_ms(xxx)' it does NOTHING else so if you send the PIC more data, it will ignore it. That's why you need to use ISRs.
hope this help... |
SherpaDoug
Posted: Sun Dec 25, 2011 7:14 am |
| Quote: | | Also when the getc() part executes does it actually clear the buffer or must I manually clear this after the getc() command. |
Assuming you are using a hardware UART the only buffer in this case is the 2 character UART hardware buffer. Getc() automatically removes the character from the buffer.
If you are using a software UART there is no buffer at all. In this case you must be waiting at getc() BEFORE the serial Start bit arrives or the character will be corrupted.
If you have a scope I would set a pin just before getc() and clear it after getc(). Use the scope to see this pin and the serial data. If the pin changes in the middle of a serial byte that is where your problem lies. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Sun Dec 25, 2011 8:16 am |
A few more comments:
- You are setting up the analog ports but not using them. The program would be shorter without these codes.
- Remove all lines in comments, this again makes the program shorter. Easier to read for us means you will get more and better responses.
- The function setup_port_a is not mentioned in my July 2011 CCS manual. I think it is an old function name and now replaced by the more meaningful name setup_adc_ports().
| Code: | char delim[]=",";
char start[]="+";
char stop[]="."; | These definitions are not used in your code and could be left out for simplicity. But, you do understand you are declaring strings here? Strings are great but you can only test the received values by using an strcmp function call. Declaring a simple single character constant is probably what you wanted and results in less code overhead: | Code: | #define DELIM ',';
#define START '+';
#define STOP '.'; |
| Code: | char c[24];
Printf("The character is correct %c\n\r",c); | This is not going to work as c is an array, i.e. the reference to c results in the _address_ of the first character where the %c specifier requires you to give the _contents_ of the character. Correct would have been: | Code: | char c[24];
Printf("The character is correct %c\n\r", &c); <<-- note the '&' |
Why make things difficult to yourself using an array when you want to hold just one character? Address calculations are difficult for the PIC and take a lot of memory. Easier and shorter code is: | Code: | char temp; <<-- note, no []
Printf("The character is correct %c\n\r", temp); |
Edit: fixed syntax error
Labjac
Posted: Sun Dec 25, 2011 9:40 am |
Hallo
I missed the first line of code when I pasted the code sorry, using a pic16f690.
The analog will be used that's why it was setup, For now I just using characters but will be using a string in future, this was a test code to try and understand characters and to setup a base for a working test program, still very new with Pic.
How would I know when I'm using hardware uart or software? |
SherpaDoug
Posted: Sun Dec 25, 2011 2:32 pm |
| Labjac wrote: | | How would I know when I'm using hardware uart or software? |
The BEST place to look is the listing file. See if the compiler is sending bytes to UART registers or to a software UART routine.
The EASIEST place to look is the PIC datasheet. See what the hardware UART RX and TX pins are. If those are the pins you are using in your #use RS23() line the compiler will most likely use the hardware, otherwise it will use software to do the job. I think sometimes if you ask for an oddball serial format the hardware can not do, the compiler must still use software even if you call for the hardware pins. _________________ The search for better is endless. Instead simply find very good and get the job done. |
