Wolfman
PIC16F876 if I/O |
Posted: Sun Dec 25, 2011 2:18 pm |
Hello guys , I am starting to learn to use a PIC16F876 in order to make simple input Output commands combined with if and else if.
I am very new in C and I assume that you will see this immediately.
I want to do a very simple task:
If Pin A1 is high
it should switch PIN B1 B2 B3 and B4 to high.
If Pin A1 is low
it should switch PIN C1.
I used the following commands:
#if defined(__PCM__)
#include <16F876.h>
#elif defined(__PCH__)
#include <18F452.h>
void main () {
if (input(PIN_A1))
output_high(PIN_B1);
output_high(PIN_B2);
output_high(PIN_B3);
output_high(PIN_B4);
if (!input(PIN_A1));
output_high(PIN_C1);
It would be very helpful for me to learn this if someone finds a problem inside this code!
Thank you so much |
SherpaDoug
Posted: Sun Dec 25, 2011 2:47 pm |
This is not the best forum to learn elementary C programming, but here are a couple of things I notice:
1) This code will run through ONCE in a few microseconds and then the PIC will go to sleep. I suspect you want the code to run continuously. There are many ways to do this but a common one is to use a while(1) loop which loops as long as 1 is true...forever.
2) You set pins high, but you never set them low. Once set high they will stay high forever.
3) Rather than two if() statements I would use if and else. If you later change one of the if()s and forget to change the other, your code may get into a third state you had not anticipated where neither or both ifs are true.
4) Get yourself a real paper book on C programming. The C Programming Language by Kernighan & Ritchie ISBN 0-13-110362-8 is my favorite. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Wolfman
Will be done |
Posted: Sun Dec 25, 2011 2:54 pm |
Hello, thanks for the perfect answer, thats more than enough to get started for me! I will also order this book!
Thank you again for this answer, helps me quite a bit
I also recognized that somebody changed the color of my text and form of it! Thanks too
This should be a working code now:
#include <16F876.h>
#include <18F452.h>
void main () {
if (input(PIN_A1))
{ output_high(PIN_B1);
Joined: 01 Jul 2010 Posts: 9164 Location: Greensville,Ontario
Posted: Sun Dec 25, 2011 4:10 pm |
Make life easier for yourself...
1) Since you're using the 876 PIC get rid of the #if defined...... and just use the 876 'setup ' code.
2) While you have your project open, press F11, and the CCS on screen help file will open. Keep it open! Very, very handy 'at your fingertips' reference on how CCS C is used.
3) Have a look at the examples that CCS supplies in the examples folder. You see how most things can be made to work.
4) When you 'revise' code, copy the old program to another file, make changes, test then save it. Repeat this often. Yes, you may have pgm1.c, pgm2.c, pgm45.c but you'll have a good record of what works and what doesn't. Just changing the same file over and over again will confuse you as a simple 'misplaced bracket' can cause you hours of grief !
5) Always add 'errors' to the use rs232(...) options. It'll keep the hardware UART from 'magically stopping'... |
SherpaDoug
Posted: Sun Dec 25, 2011 10:17 pm |
That is a start but your while(1) needs brackets {} to define what code to loop.
Code: | while (1) {
put code to loop here
Also you still never set the pins low, so once set high they will stay high forever. _________________ The search for better is endless. Instead simply find very good and get the job done. |
