I2C Problem in pic24FJ128GA010
Prada
PostPosted: Thu Dec 22, 2011 5:54 am     Reply with quote
Hi
I am currently developing a semaphore system, based on pic24fj128ga010, everything is fine except the I2C communications:
The sda & scl pins are always high...
The code is attached, if anyone know the cause I was grateful:)
#include <24FJ128GA010.h>
#FUSES NOJTAG //JTAG disabled
//#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES PR //Primary Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES HS //External clock with CLKOUT
//#use fast_io(A)
#use fast_io(E)
#use fast_io(C)
#use delay(clock=32000000)
#use i2c(Master,sda=PIN_A3,scl=PIN_A2)
#include <max7312.c>
max7312.c
#ifndef MAX7312_DATA
#define MAX7312_DATA  PIN_A3
#define MAX7312_CLK   PIN_A2
#endif
//prototypes
int8 max7312_read(int8 device, int8 address);  //reads 7312 control register
void max7312_write(int8 device, int8 address, int8 data);   //writes 7312 control register
Thank you for listening and if you know the solution ;)
PostPosted: Thu Dec 22, 2011 7:01 am     Reply with quote
Do you have the correct pullup resistors on the I2C lines for your speed,PCB layout,etc.?
Have you tried another I2C device(say an RTC like the DS1307 )?
Only code snippets are shown, we'll need to see a small,compileable program that fails to offer more help.
Prada
I2C problem pic24fj128ga010
PostPosted: Thu Dec 22, 2011 7:57 am     Reply with quote
Thanks for the reply,
I have use 4.7k pullup resistors.
I've done the scan with the oscilloscope, and there is no clock or data.
following is a small program to compile.
//Main.c
//#use fast_io(A)
#use fast_io(E)
#use fast_io(C)
//#use i2c(MASTER, sda=PIN_G3, scl=PIN_G2, Fast, Force_sw)
#word AD1PCFG=0xffff
int1 RADAR1,RADAR2,PEAO;
void main(void) {
while(1){
   output_high(PIN_A4);
   max7312_init_output(0x46) ;
   PEAO=0;
   RADAR1=0;
   RADAR2=0;
    while(true)
     max7312_write(0x46,0x02,0b01001100); //1ª fase
     max7312_write(0x44,0x02,0b00000010);
     max7312_write(0x46,0x02,0b01001010);//2ª fase
     max7312_write(0x46,0x02,0b10100001); //3ª fase
     max7312_write(0x44,0x02,0b00000001);
     max7312_write(0x46,0x02,0b10010001); //4ª fase
//max7312.c
#endif
//prototypes
void max7312_init_output(int8 device) { //Alterei esta função
   output_float(MAX7312_CLK);
   output_float(MAX7312_DATA);
   max7312_write(device,0x06,0x00);  //configura porto 1 como saída
   max7312_write(device,0x02,0x00); //Coloca o porto 1 como saída(Mudar para 0x00 onde está o 0xFF)
void max7312_init_input(int8 device) { //Alterei esta função
   max7312_write(device,0x06,0x11);  //configura porto 1 como entrada
int8 max7312_read(int8 device, int8 commandByte) {
   BYTE data;
   i2c_start();
   i2c_write(device);       //endereço do escravo
   i2c_write(commandByte);  //commando de entrada
   i2c_start();
   i2c_write(commandByte | 1);//escreve endereço com read=1
   data=i2c_read(0);         //sem ack pq vai parar a seguir
   i2c_stop();
   return(data);
void max7312_write(int8 device, int8 address, int8 data) {
   i2c_start();
   i2c_write(device);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
FvM
PostPosted: Thu Dec 22, 2011 5:09 pm     Reply with quote
The shown code executes 2 lines continuously, but no I2C actions.
while(1){
Prada
PostPosted: Fri Dec 23, 2011 3:53 am     Reply with quote
It works Very Happy
I was so focused on the I2C set, which I did not notice this error in the program Shocked
Thanks for the help Razz
