georpo
Joined: 18 Nov 2008 Posts: 278 Location: Athens, Greece.
PIC16F1934 TRIS |
Posted: Thu May 20, 2010 12:22 am |
I am using a PIC16F1934 to interface a custom made lcd.
I cannot get the tris registers to work. The "set_tris" function does not work.
I tried this:
#byte TRISA = 0x8C
#byte TRISB = 0x8D
#byte TRISC = 0x8E
#byte TRISD = 0x8F
#byte TRISE = 0x90
TRISA=0b00001100;
TRISB=0b00000110;
TRISC=0b00011000;
The above should work but the disassembly listing says:
TRISA=0b00001100;
MOVLW 0xc
MOVWF 0xc
TRISB=0b00000110;
MOVLW 0x6
MOVWF 0xd
TRISC=0b00011000;
MOVLW 0x18
MOVWF 0xe
for some reason it writes to the PORT register and not the tris register.
And the strangest thing, I tried this in assembly:
#asm
CLRF 0x8C
MOVLW 0x6
MOVWF 0x8d
MOVLW 0x18
MOVWF 0x8e
CLRF 0x8f
#endasm
The result is again:
#asm
CLRF 0x8C
CLRF 0xc
MOVLW 0x6
MOVLW 0x6
MOVWF 0x8d
MOVWF 0xd
MOVLW 0x18
MOVLW 0x18
MOVWF 0x8e
MOVWF 0xe
CLRF 0x8f
CLRF 0xf
#endasm
It does not write to the register that I want. It write to the port register.
Any help appreciated.
George. |
Posted: Thu May 20, 2010 12:34 am |
This type of PIC was recently added to the compiler. What's your
compiler version ? |
georpo
Posted: Thu May 20, 2010 3:25 am |
4.093 |
georpo
Posted: Thu May 20, 2010 4:25 am |
And another question,
where is the EEPROM located? org 0x2100 does not work. |
Posted: Thu May 20, 2010 4:52 am |
Look a few lines _above_ the assembler you show. The compiler will not switch banks, if it is already using the right page. Writing to address 0c, would be 'right', if the BSR is already pointing to the required page...
On the EEPROM, details of this are always found in the 'programming' data sheet for the chip. 0x1E000 for your chip.
georpo
Posted: Thu May 20, 2010 5:01 am |
Ok, I agree with the bank Nr as far as it goes for assembly but in C it should work with the method below without caring about the banks. right?
#byte TRISA = 0x8C
#byte TRISB = 0x8D
#byte TRISC = 0x8E
#byte TRISD = 0x8F
#byte TRISE = 0x90
TRISA=0b00001100;
TRISB=0b00000110;
TRISC=0b00011000;
I have already tried 0x1E000, it does not work.
#rom 0x1E000= {0,1,32,45,66,75}
Any ideas?
Thanks for the reply! |
georpo
Posted: Thu May 20, 2010 5:11 am |
I found a post by PCM programmer, he says:
http://www.ccsinfo.com/forum/viewtopic.php?t=42386&highlight=0x2100
Quote: |
To get the physical address in the PIC, divide the Hex file address by 2.
This means the data eeprom starts at 0xF000.
I tried this and it works.
One problem solved!
Now, I am searching for the tris problem.
Thanks! |
Posted: Thu May 20, 2010 3:26 pm |
I installed vs. 4.093 and compiled the following test program:
#include <16F1934.h>
#fuses INTRC_IO, NOWDT, PUT, NOLVP
set_tris_a(0x55);
set_tris_b(0xAA);
set_tris_c(0x22);
Here is part of the .LST file, with my comments added.
It shows that the correct TRIS register addresses are being used.
The TRIS registers are in Bank 1, and that's the currently selected
bank in the code below:
0016: MOVLB 01 // Bank 1
0017: CLRF 17 // WDTCON = 0
0018: MOVLW 07
0019: MOVWF 1C // ADRESH = 0 ***Bug: not needed
.................... set_tris_a(0x55);
001A: MOVLW 55
001B: MOVWF 0C // TRISA = 0x55
.................... set_tris_b(0xAA);
001C: MOVLW AA
001D: MOVWF 0D // TRISB = 0xAA
.................... set_tris_c(0x22);
001E: MOVLW 22
001F: MOVWF 0E // TRISC = 0x22
georpo
Posted: Thu May 20, 2010 11:06 pm |
Yes, but TRISA = 0x8C and not 0xC.
Am I missing something here? |
Posted: Thu May 20, 2010 11:33 pm |
It's all about bank selection. Look at this table in the PIC data sheet:
Quote: | TABLE 3-3: PIC16F1933/1934 MEMORY MAP, BANKS 0-7 |
Find the row for 00Ch on the left. Then find the column for Bank 1.
Now find the intersection of the row and the column. It says "TRISA".
That's because it's at offset 0x0C and it's in Bank 1. Look just to the
left of "TRISA", and you'll see the address, which is 0x8C. |
Sica001
Posted: Wed Dec 14, 2011 2:51 am |
I try yesterday with 4.129 version and problem is not solved. In my program output is ok but input not work(even input_state). Somebody know how to solve this problem ?
Regards
Marius |
Posted: Wed Dec 14, 2011 7:50 am |
Marius,
Please don't ask your new and unrelated question in a thread that was solved and closed 1.5 years ago.
We have no clue what you are talking about.
Start a new thread. Post a short but complete example program of maximum 20 lines. If the question is related to inputs and outputs then describe in short the hardware connected to these pins, even better, post a schematic. |
