LCD expand I/o pcf8574
plainas
PostPosted: Wed Dec 07, 2011 5:45 pm     Reply with quote
Good people, I am new to forum and would like to start sharing my ideas with you ... I've done several projects, nothing special but I know a few things.
I wanted to do now was to put an LCD connected to a PCF8574 to then turn on the pic for I2C. Anyone have any piece of C code for the PIC to make that communication with the PCF8574?
Thank you for your attention ...
PostPosted: Thu Dec 08, 2011 6:43 am     Reply with quote
Yes, it can be done(commerical units available) but since the LCD would be used in 4 bit mode,using I2C will only save you 4 pins.As I2C is a short distance bus( onboard or close to PIC), you'ld probably be better using the 'flex_driver' for the LCD.You can always 'mux' the pins for other uses.
But..if you need the code, let Google find it for you. It is out 'there',though you may have to convert to CCS C.
PostPosted: Thu Dec 08, 2011 7:07 am     Reply with quote
It's in the Code Library. Please try search before you ask!
