MISRA rule violation
micsch
PostPosted: Tue Dec 06, 2011 1:21 am     Reply with quote
I get a rule violation by MISRA (2004) when I use Pre-Processor directives like #FUSES, #device , #int_TIMER0 and so on.
The rule is:
[ MISRA 19.16 ] Preprocessing directives shall be syntactically meaningful even when excluded by the preprocessor.
How can I handle this?
Any help would be greatful.
//Configuration uC in Headerfile
#device adc=8                                                   /*Aufloesung AD-Wandler in Bit                    */
#FUSES NOWDT                                                    /*No Watch Dog Timer                              */
#FUSES INTRC_IO                                                 /*Internal RC Osc                                 */
#FUSES PUT                                                      /*Power Up Timer                                  */
#FUSES NOPROTECT                                                /*Code protected from reads                       */
#FUSES MCLR                                                     /*Master Clear pin enabled                        */
#FUSES NOCPD                                                    /*No EE protection                                */
#FUSES BROWNOUT                                                 /*brownout reset                                  */
#FUSES NOIESO                                                   /*Internal External Switch Over mode disabled     */
#FUSES NOFCMEN                                                  /*Fail-safe clock monitor disabled                */
#FUSES NODEBUG                                                  /*No Debug mode for ICD                           */
#use delay(clock=2000000)                                       /*System-Clock = Oszillator-Clock:4 = 500'000 kHz */
#use i2c(master, sda=PIN_C7, scl=PIN_C6, slow)                  /* Configure Device as Master                     */
and by the two ISR in the C-file:
   #int_TIMER0
void timer0Isr( void )
   #int_TIMER1
void timer1Isr( void )
RF_Developer
PostPosted: Tue Dec 06, 2011 2:33 am     Reply with quote
Tricky...
It may be complaining at the comments after the directives. It may be worried about the white spaces before, which are not allowed in strict C. It may be expecting only a well-defined set of directives, such as #define, #ifdef #else and other conventionally used preprocessor directives. The fact is that to CCS C, but not a generic C as possibly is expected by your MISRA test suite, these are syntactically meaningful. I'm not totally sure I know what the MISRA standard means by "exclusion by the preprocessor". Given, also that CCS, like so many other C compiler implementations these days integrates pre-processor functionality with the compiler, doing it all effectively in one pass.
How you deal with this is another matter. You have to take a view as to treat this as a warning, and work round it.
RF Developer
micsch
PostPosted: Tue Dec 06, 2011 3:18 am     Reply with quote
Probably you are right. It seems that MISRA-rule does not know these directives and generates the violation. So there is not a possibility to fix it.
I will ask this in MISRA.org.uk, maybe they know what to do.
Many thanks.
RF_Developer
PostPosted: Tue Dec 06, 2011 5:32 am     Reply with quote
This is another example that's covered by what Ttelmah pointed out
"It is recognized that it may be necessary to raise deviations (as described in section 5.3.2) to permit certain language extensions, for example to support hardware specific features."
Configuring the fuses, just as with the ADC, is such a feature.
RF Developer
