dsPIC30F some outputs not switching
Ben_Dinsdale
PostPosted: Mon Dec 05, 2011 9:59 am     Reply with quote
I'm currently debugging a prototype siren based around the dsPIC30F5011. I'm using CCS C v4.057, MPLAB v8.63, and ICD3 as the debugger.
I'm having trouble getting RD2 and RD3 to switch on.
These pins can also be compare pins which I have turned off.
SETUP_COMPARE(3, COMPARE_OFF);
SETUP_COMPARE(4, COMPARE_OFF);
and configured as outputs
SET_TRIS_D(0b0000011100100001);
I'm currently at the very simple do the inputs and outputs work stage.
while(TRUE) // never ending loop
{ // start of never ending while loop
delay_ms(20);
get_inputs(); // read in positive and negative inputs
if (input1)output_high(PIN_D3);
else output_low(PIN_D3);
This is code is working on pins D1, D4-D8, but not on D2 and D3 as I can see PORTD and LATD being switched in the watch window.
However in the case of D2 and D3 I only see LATD being switched whilst PORTD remains 0.
Any help or suggestions would be greatly appreciated.
Ben
