IEEE_az
Motor pwm with dspic30f4011 |
Posted: Fri Dec 02, 2011 8:17 pm |
Hi everybody, I want to work with the pwm motor module in my dspic30f4011. I use instructions like setup_motor_pwm(), set_motor_unit(), and set_motor_pwm_duty(), but always those pins are at 0v (RE0, RE1, RE2, RE3, RE4, RE5). Maybe someone knows how I should set the module and give me a little help. Thanks, bye. |
