INT_RTCC Undefined...
Wipster
PostPosted: Wed Nov 30, 2011 10:47 am     Reply with quote
Here is a little test program which illustrates the issue, zero function to it.
I'm using MPLAB 8.80 and CCS 4.124.
The compiler says, 'Invalid pre-processor directive' and 'Undefined identifier INT_RTCC'
I have looked in the datasheet and this part appears to have interrupts, as this was the reason for this error in a previous topic. I'm a little stumped.
#include <12F1840.h>
int i;
#INT_RTCC
void clock_isr()
  i++;
   set_rtcc (0);
   enable_interrupts (GLOBAL);
   enable_interrupts (INT_RTCC);
RF_Developer
PostPosted: Wed Nov 30, 2011 11:00 am     Reply with quote
Try #INT_TIMER0 instead. CCS have been trying to wean folks off the old style RTCC definitions for ages. The reason for this is probably as many PICs have a true RTC peripheral these days. Though not the PIC12F18740.
RF Developer
Wipster
PostPosted: Wed Nov 30, 2011 11:10 am     Reply with quote
Ahha yep, golden. Cheers for that! Going to go over the .h with a fine tooth comb and check everything next time, would have spotted the lack of RTCC.
