PIC32 fast pin toggle
georpo
PostPosted: Wed Nov 16, 2011 2:01 am     Reply with quote
Hello!
Is it possible to toggle an I/O pin at the cpu speed?
Let's say the PIC32 runs at 80MHz.
If I toggle the pin, will I get 40MHz output?
I know this is possible with all other PIC series but I could not
do it with PIC32...
Thanks.
George.
PostPosted: Wed Nov 16, 2011 3:39 am     Reply with quote
This is not possible on _any_PIC.....
I think you may possibly be confusing Fosc (the internal clock oscillator frequency), with the OSC input frequency.
On all the older PICs, the fastest you can operate an output pin, is with the PWM, at Fosc/4.
What you _can_ do on most of the PIC18 chips is run with an external oscillator (OSC) at (say) 10MHz, and generate internally an Fosc faster than this, with the PLL. So running with a 10MHz external clock, you then run Fosc at 40MHz, and can toggle a pin at 10MHz. However this is still 1/4 of the actual Fosc.
If you think about it the timers (limiting factor on speed), don't clock faster than the oscillator frequency (unless you use an external clock....), so it takes a minimum of two cycles of the oscillator clock to give a high and a low pulse period. This is the fastest you can go with the PIC32.
You really need to be on the Microchip hardware forums. CCS doesn't support the PIC32, and this is a forum for _CCS_ code support.
georpo
PostPosted: Wed Nov 16, 2011 9:04 am     Reply with quote
Yes, this is what I mean.
Of course I do not mean the oscillator frequency. I mean the TCY.
For example, with a PIC16 series with 20MHz crystal, the internal TCY is 5MHz. So if I toggle the pin, I get 2.5MHz.
I also do that with PIC18, DSPIC and PIC24.
Of course DSPIC and PIC24 chips divide by 2.
The question is:
1) Does the PIC32 divide the clock? By 2? by 4?
2) can I toggle the io pin at these speeds?
I already tried it with a PIC32 running at 80MHz but the output is only
2.5MHz. It must be some configuration issue.
George.
drh
PostPosted: Wed Nov 16, 2011 9:14 am     Reply with quote
As Ttelmah said.
"You really need to be on the Microchip hardware forums. CCS doesn't support the PIC32, and this is a forum for _CCS_ code support."
David
