benoitstjean
Joined: 30 Oct 2007 Posts: 564 Location: Ottawa, Ontario, Canada
LCD on port B and external interrupt B0 together |
Posted: Wed Dec 05, 2007 1:58 pm |
Just thought I'd share this info:
I usually use PORT B to drive an LCD display. I have a situation at the moment where I need to use external interrupt on port B0 along with the LCD display. In the LCD.C file provided by PICC compiler, I changed the pinout in the lcd struct to have B0 unused instead of the default (B3 I believe).
Anyhow, the problem I was having was when CCS's LCD driver accessed the LCD display, it would always make B0 an output and stop the external interrupt from responding.
I finally realized that the LCD.C file provided by CCS has one bit on the port that is unused. I changed it to be B0 but didn't realize that the set_tris_b function in the LCD.C file always set that bit to 0, so as output.
Anyhow, changing the bit to a 1 in the LCD.C file solved the problem. I realize it's not a big issue but when you don't think of it, then it's a different story. And if it can be of any help to anyone, then that's great.
Here are my modifications to the original file:
#define use_portb_lcd TRUE
struct lcd_pin_map
{ // This structure is overlayed
BOOLEAN unused; // on to an I/O port to gain
BOOLEAN enable; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN rs; // low order up. ENABLE will
int data : 4; // be pin B1.
} lcd;
struct lcd_pin_map const LCD_WRITE = {1,0,0,0,0}; // For write mode all pins are out (except B0 which stays as input)
struct lcd_pin_map const LCD_READ = {1,0,0,0,15}; // For read mode data pins are in (except B0 which stays as input)
ateso3486 Guest
Thanks |
Posted: Thu Jan 03, 2008 6:07 pm |
Thanks you saved my life
I was in your situation. And because of lcd driver, my interrupts only worked for first time. Three days, i was trying to solve this. And this topic, i got the answer. Thanks a lot, benoitstjean. |
Gaston
Excelent post ! |
Posted: Sat Nov 05, 2011 1:42 pm |
I know this post maybe a little old !.. BUT.. I was finding that info some hours ! Every day Everybody learns something new !
Thanks Bro !
Gaston from Argentina. |
